Re: New best this weekend!
[Re: GY3]
#2813455
08/26/20 09:34 AM
08/26/20 09:34 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
Some food for thought and just my opinion...don't try to go too much faster w/ a heavy car. It gets way more expensive and less fun. It has it's fun times, like when everything goes good at the track, but I think I had more fun w/ the car running mid to low 10s. It was all motor then too, which was a lot less work and aggravation. No plans to push it too much further. Would like to do a 9.99 once, but the stars would have to align. it will absolutely not get cut up or lightened up any further! Just a little more nitrous........
68 Barracuda Formula S 340
[Re: Bad340fish]
#2813474
08/26/20 09:57 AM
08/26/20 09:57 AM
Posts: 4,715 Wichita
GY3
Wichita
Some food for thought and just my opinion...don't try to go too much faster w/ a heavy car. It gets way more expensive and less fun. It has it's fun times, like when everything goes good at the track, but I think I had more fun w/ the car running mid to low 10s. It was all motor then too, which was a lot less work and aggravation. No plans to push it too much further. Would like to do a 9.99 once, but the stars would have to align. it will absolutely not get cut up or lightened up any further! Just a little more nitrous........ ...and an aftermarket block, and better heads...
[Re: GY3]
#2815995
09/01/20 08:37 PM
09/01/20 08:37 PM
Posts: 4,701 On the parachute mount
n20mstr
Some food for thought and just my opinion...don't try to go too much faster w/ a heavy car. It gets way more expensive and less fun. It has it's fun times, like when everything goes good at the track, but I think I had more fun w/ the car running mid to low 10s. It was all motor then too, which was a lot less work and aggravation. No plans to push it too much further. Would like to do a 9.99 once, but the stars would have to align. it will absolutely not get cut up or lightened up any further! Just a little more nitrous........ ...and an aftermarket block, and better heads... I have been 9 teens and 9.20's pretty regularly with a 446 (stock block and crank) indy 440-1s with two stacked plates, @ 3400lbs .......IT can be done LOL i had a 440 with ported 906's and a .509 cam , went 10.40's with that (STOCK ROCKERS) LOL
....BAD A$$ STREET CAR.....
[Re: BSB67]
#2816067
09/02/20 01:15 AM
09/02/20 01:15 AM
GY3
Wichita
n2omstr, I only recently started playing with nitrous and I'm taking baby steps with it.
I wanted to do it right and studied up on it thoroughly prior to pulling the trigger. I just recently installed a bottle heater and have the pressure switch adjusted to keep it exactly where I want it.
[Re: GY3]
#2816074
09/02/20 01:35 AM
09/02/20 01:35 AM
Posts: 43,355 Bend,OR USA
Cab_Burge
Not trying to hijack this thread but hearing about bottle pressures on NOS system a lot, how important is that? Doesn't it need a certain amount of pressure to keep it in liquid form? Doesn't it turn into gas without that pressure?
[Re: Cab_Burge]
#2816112
09/02/20 07:46 AM
09/02/20 07:46 AM
Bad340fish
Tulsa OK
Not trying to hijack this thread but hearing about bottle pressures on NOS system a lot, how important is that? Doesn't it need a certain amount of pressure to keep it in liquid form? Doesn't it turn into gas without that pressure? I am not a nitrous expert by any means but more pressure obviously equals more nitrous. You want to be consistent because that is a variable in your tune up. I once broke the spring perches, driveshaft, and sprag because I tried to make a run with a hot bottle knowing it would make my junk faster because it was a little rich lol. I don't play with nitrous anymore haha.
[Re: Cab_Burge]
#2816124
09/02/20 08:44 AM
09/02/20 08:44 AM
GY3
Wichita
Not trying to hijack this thread but hearing about bottle pressures on NOS system a lot, how important is that? Doesn't it need a certain amount of pressure to keep it in liquid form? Doesn't it turn into gas without that pressure? Very important! Right around 1000 psi or 91*-92* bottle temp is optimum.
[Re: GY3]
#2816137
09/02/20 09:35 AM
09/02/20 09:35 AM
n20mstr
I wanted to do it right and studied up on it thoroughly prior to pulling the trigger. I just recently installed a bottle heater and have the pressure switch adjusted to keep it exactly where I want it. Let it rip ..... lol Don’t know what heads you have . Just be careful with timing . Most BBM heads are now t nitrous friendly . And your cam probably not tailored for opening exh early to get the heat out . But what your using is not a lot . You doing Great , baby steps ..... just hurry up and get it in the 9’s . And I bet that won’t be enough for you .... lmao We all say X but always want more ! Happy ET hunting !
[Re: n20mstr]
#2816144
09/02/20 09:57 AM
09/02/20 09:57 AM
GY3
Wichita
I wanted to do it right and studied up on it thoroughly prior to pulling the trigger. I just recently installed a bottle heater and have the pressure switch adjusted to keep it exactly where I want it. Let it rip ..... lol Don’t know what heads you have . Just be careful with timing . Most BBM heads are now t nitrous friendly . And your cam probably not tailored for opening exh early to get the heat out . But what your using is not a lot . You doing Great , baby steps ..... just hurry up and get it in the 9’s . And I bet that won’t be enough for you .... lmao We all say X but always want more ! Happy ET hunting ! I'm using a Nitrous Express Mainline kit and the next step up, 250hp, is pretty much the limit of the tiny solenoids. As I recall the nitrous jet for that is like a 137, so no jet at all, just straight through. LOL! We built a custom china rail hold down for the solenoids and make it semi hidden and look a little cleaner.
[Re: n20mstr]
#2816188
09/02/20 11:59 AM
09/02/20 11:59 AM
GY3
Wichita
What heads are you using on that engine ? Modern Cylinder Head ported Stealths.
[Re: GY3]
#2816204
09/02/20 12:30 PM
09/02/20 12:30 PM
n20mstr
What heads are you using on that engine ? Modern Cylinder Head ported Stealths. Best upgrade you can make , put a -6 feed line , get a larger orifice nitrous solenoid . Whatever you can do to feed the jet you will pick up . Even at the same jet . Also I noticed you have grounds separate , I would have both solenoid grounds together
[Re: n20mstr]
#2816212
09/02/20 12:45 PM
09/02/20 12:45 PM
GY3
Wichita
What heads are you using on that engine ? Modern Cylinder Head ported Stealths. Best upgrade you can make , put a -6 feed line , get a larger orifice nitrous solenoid . Whatever you can do to feed the jet you will pick up . Even at the same jet . Also I noticed you have grounds separate , I would have both solenoid grounds together Hmm, good to know. Will only take a minute to change.
[Re: justinp61]
#2816229
09/02/20 01:19 PM
09/02/20 01:19 PM
GY3
Wichita
I’d get rid of that plastic oil line for the pressure gauge. Yes, that was supposed to be temporary but here we are a few years later...
