lean burn thought #2812621
08/24/20 02:52 PM
08/24/20 02:52 PM
my own world
theraif Offline OP
theraif  Offline OP
my own world
if it wasnt mounted to the air pan would it have worked better
Re: lean burn thought [Re: theraif] #2812631
08/24/20 03:10 PM
08/24/20 03:10 PM
Morningside
AdventurerSport Offline
waaaay out there in left field
Morningside
I read (several years ago) an article that explained that the engineers wanted it inside the car, in a kick panel or behind the glove box. Marketing wanted it under the hood so that customers could see it (rationale was "if they can't see it then they won't believe it's there").
Not sure how true that is or not, but sounds believalbe...:)
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: lean burn thought [Re: theraif] #2812665
08/24/20 04:08 PM
08/24/20 04:08 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I thought I had an article about an engineer who came up with his own version of a more reliable Chrysler Electronics board, but only came up with this:
https://nepis.epa.gov/Exe/ZyNET.exe...p;MaximumPages=1&ZyEntry=1&slide
and this WVU student’s thesis
http://www.rommet.com/remco/thesis/
and the lean burn efforts by Ford and Toyota
https://www.howacarworks.com/technology/lean-burn-engines
Maybe the articles are on an older computer
Re: lean burn thought [Re: 360view] #2812675
08/24/20 04:27 PM
08/24/20 04:27 PM
USA
3
360view Offline
360view  Offline
3
USA
The original Chrysler Lean Burn patent listing Gordon W. Fenn from 1975
https://patents.google.com/patent/US4104998A/en?oq=4104998
Re: lean burn thought [Re: 360view] #2812681
08/24/20 04:32 PM
08/24/20 04:32 PM
USA
3
360view Offline
360view  Offline
3
USA
Allpar thoughts
https://www.allpar.com/mopar/lean-burn.html
Sample quote
If Chrysler had mounted the unit on the body instead of the air cleaner as they did in production, I think a lot of these problems could have been resolved.
End quote
Re: lean burn thought [Re: 360view] #2812748
08/24/20 07:15 PM
08/24/20 07:15 PM
my own world
theraif Offline OP
theraif  Offline OP
my own world
started to look at my 80 cordoba as in stuff i wanted to do 1st was to switch the dist. with the hei module set up, and was looking on rock auto and saw they still offer a lean burn unit work
Re: lean burn thought [Re: theraif] #2812907
08/25/20 02:01 AM
08/25/20 02:01 AM
Castlegar, BC, Canada
That AMC Guy Offline
I thought the reason it was mounted on the air cleaner was for cooling?
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: lean burn thought [Re: That AMC Guy] #2813057
08/25/20 12:53 PM
08/25/20 12:53 PM
5thAve Offline
5thAve  Offline
I think it was on the air cleaner to make it easier to get to and to design into an existing vehicle to begin with. I've only ever had one fail and it was the original style that had a ballast resistor, not the newer spark or fuel control ones form the 80s. Part of the problem with them is also the sensors that can go bad and throw things out of whack.
In the 90s GM and Ford started putting their ECMs under the hood and most are still doing it with no problems so at the very least Chrysler could have put it on the inner fender and not on the engine itself and that might have saved some potential problems from heat and vibration.
Re: lean burn thought [Re: 360view] #2819045
09/09/20 06:24 PM
09/09/20 06:24 PM
USA
3
360view Offline
360view  Offline
3
USA
Lean burn engine development is still going on.
Here’s is an article from today on plasma spark plugs to ignite lean air to fuel ratios
https://www.wired.com/story/is-lightning-fast-plasma-the-key-to-a-cleaner-car-engine/
Sample quote
The efficiency of a combustion engine is deeply dependent on how it's being used. For example, engines tend to be least efficient at low speeds and low power, a scenario that might be encountered when driving through a city. So Sjöberg and the Transient Plasma team tested the ignition system in the engine across a range of operating modes that loosely correlated with different scenarios, like driving on the highway. During the tests at Sandia, Transient Plasma System’s plug demonstrated that it could offer up to a 20 percent improvement in fuel efficiency in these driving modes, relative to the performance of a commercial combustion engine with a conventional spark plug.
Singleton says the results from the Sandia tests soon attracted the attention of the auto industry. For the past few years, Transient Plasma Systems has been working with several undisclosed car manufacturers to test the system with the companies’ engines. He says he is optimistic that the first cars to use the system could be on the road within the next five years.
End quote
Re: lean burn thought [Re: 360view] #2819081
09/09/20 08:19 PM
09/09/20 08:19 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Just read about this
Re: lean burn thought [Re: 360view] #2819745
09/11/20 05:04 PM
09/11/20 05:04 PM
SE Indiana
K
kowalski440 Offline
kowalski440  Offline
K
SE Indiana
I seem to recall Smokey Yunick talking about plasma ignition way back in the 70's. The tech wasn't there yet, though. Sounds like it might be catching up.
