Re: lean burn thought
[Re: theraif]
#2812631
08/24/20 03:10 PM
08/24/20 03:10 PM
Posts: 6,018 Morningside
AdventurerSport
waaaay out there in left field
Morningside
I read (several years ago) an article that explained that the engineers wanted it inside the car, in a kick panel or behind the glove box. Marketing wanted it under the hood so that customers could see it (rationale was "if they can't see it then they won't believe it's there").
Not sure how true that is or not, but sounds believalbe...:)
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
[Re: 360view]
#2812681
08/24/20 04:32 PM
08/24/20 04:32 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Allpar thoughts https://www.allpar.com/mopar/lean-burn.htmlSample quote If Chrysler had mounted the unit on the body instead of the air cleaner as they did in production, I think a lot of these problems could have been resolved. End quote
[Re: 360view]
#2819045
09/09/20 06:24 PM
09/09/20 06:24 PM
Posts: 8,162 USA
360view
USA
Lean burn engine development is still going on. Here’s is an article from today on plasma spark plugs to ignite lean air to fuel ratios https://www.wired.com/story/is-lightning-fast-plasma-the-key-to-a-cleaner-car-engine/Sample quote The efficiency of a combustion engine is deeply dependent on how it's being used. For example, engines tend to be least efficient at low speeds and low power, a scenario that might be encountered when driving through a city. So Sjöberg and the Transient Plasma team tested the ignition system in the engine across a range of operating modes that loosely correlated with different scenarios, like driving on the highway. During the tests at Sandia, Transient Plasma System’s plug demonstrated that it could offer up to a 20 percent improvement in fuel efficiency in these driving modes, relative to the performance of a commercial combustion engine with a conventional spark plug. Singleton says the results from the Sandia tests soon attracted the attention of the auto industry. For the past few years, Transient Plasma Systems has been working with several undisclosed car manufacturers to test the system with the companies’ engines. He says he is optimistic that the first cars to use the system could be on the road within the next five years. End quote
