Hello,
I have an 8.75 rear end that I think is from a 70 b body and I need to get the axle brake lines. Can someone give me the length from the drivers side wheel cylinder to the brass junction block? I called some of the brake line places and they were not able to give me an overall length of their brake line after it was bent. The axle is not in a 70 b body so that is the reason for the question and I see online that 69 and earlier and 70 have the junction block in a slightly different location in relation to the wheel cylinders.
Thank you!
Matt
