Blend Door Issue #2812536
08/24/20 12:09 PM
08/24/20 12:09 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
89 Dakota 3.9 V6. All of a sudden when I accelerate, the AC goes from the dash vents to the floor vents and then back to the dash vents. I replaced a section of that thin plastic line coming from the fire wall to the heater valve again. It always worked in the past, but now the AC is stuck on the floor vents. ??
Grandma always said I had "hands of gold"!
Re: Blend Door Issue [Re: CHRGR69] #2812601
08/24/20 02:16 PM
08/24/20 02:16 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I think Dodge added, or installed a vacuum canister under the hood to solve this problem. You may want to look for that canister and be sure everything is OK with it. Its under the hood on the passenger side, tucked way down low, it looks like an old coffee can painted black and has a few hose connections on it. Gene
Re: Blend Door Issue [Re: poorboy] #2812640
08/24/20 03:27 PM
08/24/20 03:27 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Pretty good odds are you have a vacuum leak or bad vacuum actuator
Re: Blend Door Issue [Re: poorboy] #2812645
08/24/20 03:34 PM
08/24/20 03:34 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
No coffee can on this truck. I do have one in my Charger so I knew exactly what to look for. Anyway, I reexamined the white plastic line and it was fine, but the black line right next to it was hanging by a thread. AC working fine now. When it gets cooler here in Florida, I'll trace those 2 lines back behind the fire wall and replace them both. up
Re: Blend Door Issue [Re: gtx6970] #2814987
08/30/20 12:45 AM
08/30/20 12:45 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Check all the actuators and hoses under the dash. Any leakage is going to cause problems.
