Universal Aluminum Radiator question........... #281236
04/08/09 08:44 AM
04/08/09 08:44 AM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
I've been looking at a couple different universal radiators and looks as if they do not have transmission cooler hook ups or petcocks? Am I not seeing this right or is that how they come?
How is one supposed to hook up their transmission coolant lines if that's the case?
Re: Universal Aluminum Radiator question........... [Re: 74RR] #281237
04/08/09 10:38 AM
04/08/09 10:38 AM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
If you need a cooler built in, Summit lists lots of radiators with coolers see:
http://store.summitracing.com/egnsearch....mp;autoview=sku
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Universal Aluminum Radiator question........... [Re: 74RR] #281238
04/08/09 10:41 AM
04/08/09 10:41 AM
IL
71dusta Offline
71dusta  Offline
IL
Just buy a aftermarket tranny cooler and run the lines to that mounted in front of the radiator. It's easy they usually come with the plastic zip holders that run thru the radiator to hold them on.
Automotive and Kustom Art www.nategrice.blogspot.com
Re: Universal Aluminum Radiator question........... [Re: 71dusta] #281239
04/08/09 11:06 AM
04/08/09 11:06 AM
74RR Offline OP
74RR  Offline OP
I have a aftermarket trans cooler,a B & M one that I haven't used yet.
Would that be enough to cool my transmission?
Re: Universal Aluminum Radiator question........... [Re: 74RR] #281240
04/08/09 11:10 AM
04/08/09 11:10 AM
Yes it would
Re: Universal Aluminum Radiator question........... [Re: RapidRobert] #281241
04/08/09 11:30 AM
04/08/09 11:30 AM
74RR Offline OP
74RR  Offline OP
Thanks,I should mention that is a street driven car. Would that make a difference?
Re: Universal Aluminum Radiator question........... [Re: 74RR] #281242
04/08/09 05:13 PM
04/08/09 05:13 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run mine in front of the radiator hooked to it with the tie straps they give you. You can see it a bit in this pic on the radiator. I have had it on my car for 3 years withn no problems and I drive it all over. Ron
Re: Universal Aluminum Radiator question........... [Re: 383man] #281243
04/08/09 09:24 PM
04/08/09 09:24 PM
74RR Offline OP
74RR  Offline OP
So Ron you run your coolant lines from the transmission to the transmission cooler and back without using the radiator? !
Re: Universal Aluminum Radiator question........... [Re: 74RR] #281244
04/09/09 08:10 PM
04/09/09 08:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes I do. Ron
