cleaning fuse panel / terminals / wire harness #2811577
08/21/20 12:11 PM
08/21/20 12:11 PM
eastern L.I. ,NYC
K
kingdragon Offline OP
K
eastern L.I. ,NYC
Any of you guys have any suggestions on cleaning the terminals and fuse block on my dash harnesses? I was thinking about soaking the fuse block in a bowl of vinegar. My other idea is maybe evaporust. I want to put my harness terminals to look as nice as the flawlessly restored dash assembly. Looking forward to the responses. Working knowledge is best.
-KD
I only buy MADE IN USA.
Re: cleaning fuse panel / terminals / wire harness [Re: kingdragon] #2811588
08/21/20 12:25 PM
08/21/20 12:25 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
If the terminals and fuse clips are just oxidized and /or light surface rust, use an abrasive pencil ink eraser or emory cloth to polish....
Also don't forget to bend inward slightly the tension on the fuse clips as well..
Just my $0.02... wink
Re: cleaning fuse panel / terminals / wire harness [Re: kingdragon] #2811606
08/21/20 12:51 PM
08/21/20 12:51 PM
Downey, CA.
BB14404SPD Offline
BB14404SPD  Offline
Downey, CA.
CAIG DeoxIT Spray
Re: cleaning fuse panel / terminals / wire harness [Re: kingdragon] #2811609
08/21/20 12:54 PM
08/21/20 12:54 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I used a brass brush along with some electrical contact cleaner and then also a product from CRC (cant recall product name) that was a wiring protectant. Kind of an oil. I wiped the terminals and cleaned the insulation the entire length looking for any breaks/cracks or issues.
I dont think evaporust works on brass.
Re: cleaning fuse panel / terminals / wire harness [Re: kingdragon] #2811611
08/21/20 12:54 PM
08/21/20 12:54 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Deoxit D5 from Amazon. Will remove light corrosion and protect in the future. More aggressive corrosion will need to be removed an other way. Soaking in evaporust or vinegar would work, but be careful not to get ends of wire soaked. Liquid will wick up the strands.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: cleaning fuse panel / terminals / wire harness [Re: RoadRunner] #2811615
08/21/20 01:02 PM
08/21/20 01:02 PM
eastern L.I. ,NYC
K
K
eastern L.I. ,NYC
Do you think there would be issues in the copper strands if vinegar were in the mix?
Re: cleaning fuse panel / terminals / wire harness [Re: kingdragon] #2811684
08/21/20 03:34 PM
08/21/20 03:34 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I cut a nail file down much smaller so it fit, and cleaned my bulkhead on my Power Wagon. You could try that for fuse panel.
Facts are stubborn things.
Re: cleaning fuse panel / terminals / wire harness [Re: larrymopar360] #2811797
08/21/20 09:38 PM
08/21/20 09:38 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
yes get the cardboard nail files at wally world and cut them as needed .
works great with some electrical cleaner and air hose !
Re: cleaning fuse panel / terminals / wire harness [Re: calrobb2000] #2811835
08/22/20 06:19 AM
08/22/20 06:19 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If the harness is out of the car I've sandblasted them. Actually works pretty well.
Doug
Re: cleaning fuse panel / terminals / wire harness [Re: dvw] #2811874
08/22/20 09:43 AM
08/22/20 09:43 AM
I used a HF $10 dremel. hardly any torque but worked good on my fuse panel
Re: cleaning fuse panel / terminals / wire harness [Re: kingdragon] #2811876
08/22/20 09:45 AM
08/22/20 09:45 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
-KD
Evaporust
I soaked my bulkhead connector in it for 24 hours, rinsed with water and hit it with air. Came out squeaky clean. Removed corrosion, dirt and rust.
Abe Lincoln
Re: cleaning fuse panel / terminals / wire harness [Re: kingdragon] #2811907
08/22/20 10:59 AM
08/22/20 10:59 AM
moparx Offline
moparx  Offline
yes. vinegar is acidic.
beer
Re: cleaning fuse panel / terminals / wire harness [Re: moparx] #2811917
08/22/20 11:21 AM
08/22/20 11:21 AM
central il.
second 70 Offline
second 70  Offline
central il.
ketchup works great in a matter of minutes natural mixture of acid and vinegar.
Re: cleaning fuse panel / terminals / wire harness [Re: second 70] #2811939
08/22/20 12:10 PM
08/22/20 12:10 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
vinegar and a bit of salt, then baking soda to neutralize the acids. but thats just for sulfated/oxidized terminals, grease and dirt must be cleaned with soap, brush... etc...
Re: cleaning fuse panel / terminals / wire harness [Re: dart4forte] #2812113
08/22/20 09:46 PM
08/22/20 09:46 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
-KD
Evaporust
Wonder if I can do that with the female/fixed side of my bulkhead connector? work
More of a spray it on and wash it off type situation.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: cleaning fuse panel / terminals / wire harness [Re: GoodysGotaCuda] #2812180
08/23/20 08:55 AM
08/23/20 08:55 AM
on a side note the next bulkhead I do I am gonna replace all the brass terminals & do Nachos' bulkhead parallel bypass
Re: cleaning fuse panel / terminals / wire harness [Re: kingdragon] #2812187
08/23/20 09:27 AM
08/23/20 09:27 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I guess it depends how bad it is. If it is out of the car blasting them with the finest glass beads, or baking soda, at low pressure, like 20-30 lbs, and a flush with ideal 40-610 contact cleaner will do the trick. Walnut shells work pretty good on some of the plastic, LOW pressure. I have never been a fan of soaking crimped wire in any acidic solution, if it is that bad a new one would be wise. Never use simple green or purple power on them, stick with lacquar thinner or an eletrical contact cleaner that evaporates fast.
Re: cleaning fuse panel / terminals / wire harness [Re: 4406bbl] #2812193
08/23/20 09:37 AM
08/23/20 09:37 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I should be clear, I use size AH, or #13 glass beads, they are .001-.003 size, like dust. The crap harbor freight sells need not apply.
Re: cleaning fuse panel / terminals / wire harness [Re: GoodysGotaCuda] #2812223
08/23/20 10:56 AM
08/23/20 10:56 AM
central il.
second 70 Offline
second 70  Offline
central il.
-KD
Evaporust
I soaked these in tomato juice for several minutes and just rinsed it off. No polishing needed. Just put the connector in a cup of juice and see how it works. Mild, cheap, and non toxic.
Re: cleaning fuse panel / terminals / wire harness [Re: 4406bbl] #2812240
08/23/20 12:13 PM
08/23/20 12:13 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Looks like this after walnut shells, glass beads, flush with cleaner, why soak in acidic material? Silver tube is what I clamp on the blaster to direct beads at terminal, one I actually use has flattened tip, buy at craft stores, cake decorating section.
