cleaning fuse panel / terminals / wire harness
#2811577
08/21/20 01:11 PM
08/21/20 01:11 PM
Posts: 102 eastern L.I. ,NYC
kingdragon
eastern L.I. ,NYC
Any of you guys have any suggestions on cleaning the terminals and fuse block on my dash harnesses? I was thinking about soaking the fuse block in a bowl of vinegar. My other idea is maybe evaporust. I want to put my harness terminals to look as nice as the flawlessly restored dash assembly. Looking forward to the responses. Working knowledge is best. -KD
I only buy MADE IN USA.
Re: cleaning fuse panel / terminals / wire harness
[Re: kingdragon]
#2811588
08/21/20 01:25 PM
08/21/20 01:25 PM
Posts: 5,439 So Cal
Sinitro
So Cal
If the terminals and fuse clips are just oxidized and /or light surface rust, use an abrasive pencil ink eraser or emory cloth to polish.... Also don't forget to bend inward slightly the tension on the fuse clips as well.. Just my $0.02...
[Re: kingdragon]
#2811611
08/21/20 01:54 PM
08/21/20 01:54 PM
Posts: 5,137 East Aurora (Buffalo) NY
RoadRunner
Deoxit D5 from Amazon. Will remove light corrosion and protect in the future. More aggressive corrosion will need to be removed an other way. Soaking in evaporust or vinegar would work, but be careful not to get ends of wire soaked. Liquid will wick up the strands.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#2811615
08/21/20 02:02 PM
08/21/20 02:02 PM
kingdragon
eastern L.I. ,NYC
Do you think there would be issues in the copper strands if vinegar were in the mix?
[Re: kingdragon]
#2811684
08/21/20 04:34 PM
08/21/20 04:34 PM
Posts: 15,827 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I cut a nail file down much smaller so it fit, and cleaned my bulkhead on my Power Wagon. You could try that for fuse panel.
Facts are stubborn things.
[Re: dvw]
#2811874
08/22/20 10:43 AM
08/22/20 10:43 AM
RapidRobert
I used a HF $10 dremel. hardly any torque but worked good on my fuse panel
[Re: kingdragon]
#2811876
08/22/20 10:45 AM
08/22/20 10:45 AM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
Any of you guys have any suggestions on cleaning the terminals and fuse block on my dash harnesses? I was thinking about soaking the fuse block in a bowl of vinegar. My other idea is maybe evaporust. I want to put my harness terminals to look as nice as the flawlessly restored dash assembly. Looking forward to the responses. Working knowledge is best. -KD Evaporust I soaked my bulkhead connector in it for 24 hours, rinsed with water and hit it with air. Came out squeaky clean. Removed corrosion, dirt and rust.
Abe Lincoln
[Re: second 70]
#2811939
08/22/20 01:10 PM
08/22/20 01:10 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
vinegar and a bit of salt, then baking soda to neutralize the acids. but thats just for sulfated/oxidized terminals, grease and dirt must be cleaned with soap, brush... etc...
[Re: dart4forte]
#2812113
08/22/20 10:46 PM
08/22/20 10:46 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Any of you guys have any suggestions on cleaning the terminals and fuse block on my dash harnesses? I was thinking about soaking the fuse block in a bowl of vinegar. My other idea is maybe evaporust. I want to put my harness terminals to look as nice as the flawlessly restored dash assembly. Looking forward to the responses. Working knowledge is best. -KD Evaporust I soaked my bulkhead connector in it for 24 hours, rinsed with water and hit it with air. Came out squeaky clean. Removed corrosion, dirt and rust. Wonder if I can do that with the female/fixed side of my bulkhead connector? More of a spray it on and wash it off type situation.
[Re: GoodysGotaCuda]
#2812180
08/23/20 09:55 AM
08/23/20 09:55 AM
RapidRobert
on a side note the next bulkhead I do I am gonna replace all the brass terminals & do Nachos' bulkhead parallel bypass
[Re: 4406bbl]
#2812193
08/23/20 10:37 AM
08/23/20 10:37 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
I guess it depends how bad it is. If it is out of the car blasting them with the finest glass beads, or baking soda, at low pressure, like 20-30 lbs, and a flush with ideal 40-610 contact cleaner will do the trick. Walnut shells work pretty good on some of the plastic, LOW pressure. I have never been a fan of soaking crimped wire in any acidic solution, if it is that bad a new one would be wise. Never use simple green or purple power on them, stick with lacquar thinner or an eletrical contact cleaner that evaporates fast. I should be clear, I use size AH, or #13 glass beads, they are .001-.003 size, like dust. The crap harbor freight sells need not apply.
#2812223
08/23/20 11:56 AM
08/23/20 11:56 AM
Posts: 1,696 central il.
second 70
central il.
Any of you guys have any suggestions on cleaning the terminals and fuse block on my dash harnesses? I was thinking about soaking the fuse block in a bowl of vinegar. My other idea is maybe evaporust. I want to put my harness terminals to look as nice as the flawlessly restored dash assembly. Looking forward to the responses. Working knowledge is best. -KD Evaporust I soaked my bulkhead connector in it for 24 hours, rinsed with water and hit it with air. Came out squeaky clean. Removed corrosion, dirt and rust. Wonder if I can do that with the female/fixed side of my bulkhead connector? More of a spray it on and wash it off type situation. I soaked these in tomato juice for several minutes and just rinsed it off. No polishing needed. Just put the connector in a cup of juice and see how it works. Mild, cheap, and non toxic.
