97 Neon 2.0 DOHC-Timing belt Q
#281215
04/08/09 07:38 AM
04/08/09 07:38 AM
Posts: 3,547 stratford,ontario,canada
JD340
The car died on me yesterday morning. I got it towed out to my shop and put the Scan tool on it. I got the following codes: P1390-Timing belt skipped one or more teeth P0340-Cam sensor malfunction Am I correct in assuming the first code would trigger the second code? Malfunction might not be the right word but I don't have the book in front of me. Secondly, is the 2.0 DOHC motor an interference motor? Am I screwed? Any tips or moral support is appreciated.
Nothing to see here. Carry on.
Re: 97 Neon 2.0 DOHC-Timing belt Q
[Re: JD340]
#281216
04/08/09 08:30 PM
04/08/09 08:30 PM
Posts: 501 Kitchener, Ontario, Canada
moparrlz
super street
super street
Yes the 2 codes are related, and Yes the neon Dohc motor is an interference motor, so you probably have some bent valves. Usually the motor is fixable. The only way to tell how bad it is is by pulling the head.
Fred
[Re: JD340]
#281217
04/08/09 08:32 PM
04/08/09 08:32 PM
Posts: 12,240 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Either the timing belt jumped time or the cam broke. I have seen both. And it is an interference engine, so the head will probably have to come off to replace some intake valves. Replace the water pump while you're at it. $150-$200 in parts and 10-12 hours for most people. It can be done in less time with air tools and experience. Dual cam engines take an hour or so longer than singles and are a little bigger pain to time. If you tackle it your self, post here for some tips. Good luck!
Master, again and still
[Re: JD340]
#281218
04/08/09 08:37 PM
04/08/09 08:37 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Suggest jamming in a TDC tool in #1 plug hole, remove the timing window, crank over by hand (use socket on crank nut accesible thru plastic plug in RF wheel / splash shield), and see if both cam sprocket timing marks still line up. If not, yup, bent valves for sure. You can bend the valves cranking it by hand and not even feel it. When reassembling (new head, valves, etc.) I suggest leaving the rocker arms out until you have cranked it a few revs and are sure the sprockets are aligned. If you need a fresh head, I have a really mint low mileage genuine Mopar reman one sitting here, make offer. Rick tech@richardehrenberg.com
[Re: quickd100]
#281220
04/16/09 05:49 PM
04/16/09 05:49 PM
JD340
Wow, finally had a chance to check back in here! Thanks for the tips! Now it's decision time. The car has just over 200K's on it. I guess I'm the only one who can decide whether it's worth the effort to fix it. I hope to get into it this weekend with some help from my more experienced friend.
[Re: JD340]
#281221
04/16/09 10:29 PM
04/16/09 10:29 PM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
www.neons.org. is a good site to take a look at. Maybe you could buy a complete reman motor for cheap and drop it in. Buying Ricks head he has for sale might be a good idea.
1971 HEMI E BODY REGISTRY
