Page 1 of 3 1 2 3
What is the ideal Street/Strip Engine these days? #2812059
08/22/20 08:07 PM
08/22/20 08:07 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Curious what everyone's thoughts are?
Is it a G3 stroker or blown stroker? Is it the old standby BB wedge stroker? Is it one of those Nascar engines? is it a W9 Ritter stroker?
I look at what the Chebby guys have, and they have a good bit of choices over us in the Mopar crowd...Seems ever year that goes by there are less and less options for us.
Is an $8000 block the only way to make good Hp these days?
Re: What is the ideal Street/Strip Engine these days? [Re: Dragula] #2812069
08/22/20 08:39 PM
08/22/20 08:39 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
There would be no problem with any of the available mopar engines running reliably in the 9 second range with efi, dis& turbo.
I personally would like to get my hands into a gen3 with a centrifugal blower. Putting together something else right now though. Someday...
Re: What is the ideal Street/Strip Engine these days? [Re: Dragula] #2812077
08/22/20 08:52 PM
08/22/20 08:52 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Mostly i think it comes down to how quick you want to go . And how motor fits your car .
Big block stock stroke with reasonable rpm will last well in stock block . Aluminium is $ and iron are thin on the ground . Is Bulldog still releasing blocks ? What happened to Callies ?
Small block seems even harder to deal with than big block .
Gen3 seems ok , but you see guys moaning about lack of good blocks even now . Plus decision of efi or carb .
I have 2 rb motors now , one a factory 440 and 1 a World 505 . The 440 short has been together since 2007/8 with a couple different cams and heads . It has gone 10.70@3690 , World is below . Stock block stroker lasted about 18 months before splitting block .
Is that quick enough ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: What is the ideal Street/Strip Engine these days? [Re: Dragula] #2812088
08/22/20 09:29 PM
08/22/20 09:29 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
IMO anything you can replace the bottom end from a junkyard easily. No machine work, just something you can beat on over the weekend and then drive to work but not worry about. Less exotic the better, and plenty of stock LS or G3s making great power out there.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: What is the ideal Street/Strip Engine these days? [Re: tex013] #2812108
08/22/20 10:15 PM
08/22/20 10:15 PM
Jamey Offline
Jamey  Offline
Tex
I messaged callies this past week and new blocks are right around the corner from what I was told. Their sister company has pics posted on Facebook of new hemi blocks being machined.
Re: What is the ideal Street/Strip Engine these days? [Re: Jamey] #2812131
08/23/20 12:55 AM
08/23/20 12:55 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
For me it would be a screw blown/supercharged Gen III Hemi.
Retain all streetability, valve train stability, on pump gas.
Change pulleys, load EFI tune and add race gas ...go 8s in an A body.
The LS clowns have been doing this for ages. Ill take an OEM Gen III block over any OEM SBM or BBM block any day of the week for power handling ability.
Not cheap, but then again, what is?
Re: What is the ideal Street/Strip Engine these days? [Re: LAD 524] #2812146
08/23/20 06:54 AM
08/23/20 06:54 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
iagree Plus more aftermarket goodies are coming by the day.
Re: What is the ideal Street/Strip Engine these days? [Re: redraptor] #2812147
08/23/20 07:10 AM
08/23/20 07:10 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
For sure a Gen III hemi. I like to use Ray Meyer's Barracuda as an example. 426CID pump gas 9.7s Naturally aspirated on Drag Week in 2016. Just the ET alone is impressive to me but he DIDN'T TOUCH IT ALL WEEK, he unloaded his trunk everyday and got in the lanes.
I constantly struggle with the idea of selling this R1 W2 engine and going Gen III.
68 Barracuda Formula S 340
Re: What is the ideal Street/Strip Engine these days? [Re: Bad340fish] #2812155
08/23/20 08:19 AM
08/23/20 08:19 AM
Mo.
racerx Offline
racerx  Offline
Mo.
But…...isn't working on these dinosaurs dino the fun part of it?...…….Lol .
Re: What is the ideal Street/Strip Engine these days? [Re: racerx] #2812156
08/23/20 08:38 AM
08/23/20 08:38 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Gen III 6.4 BGE with a big turbo!
A local guy has a Dart with that combo. He's been an easy 5.16 in the 1/8th and drives it to work all the time...
'63 Dodge 330
11.19 @ 121 mph
Re: What is the ideal Street/Strip Engine these days? [Re: racerx] #2812159
08/23/20 08:43 AM
08/23/20 08:43 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
...that's a great point!
All around me the go-fast guys are running turbos or super-charged motors, none of them are Mopar. Heck, my daily driver is a turbo and I can't lie to you, it's a boat-load of fun.
BUT
Part of the reason for me to be engaged in the hobby was (and still is) the ability to affect the outcome with my know-how and by being very hands-on. Not to say going non-NA isn't that, but somehow it feels like that route would take away some of that.
For that reason, a go-fast approach for me would be to build a blown motor. Heck, that's the plan for my '81 coupe...
Re: What is the ideal Street/Strip Engine these days? [Re: Dragula] #2812161
08/23/20 08:44 AM
08/23/20 08:44 AM
The Great State of PA
tabletop390 Offline
tabletop390  Offline
Gen III Hemi all the way. Talking to companies at the PRI show last year, they feel it’s the next LS. Holley is already talking about “going all in” over the Hemi. Buying a complete Hellcat setup is really easy today too. A lot of companies will sell you a complete pallet with everything you need to drop it in. Imagine having a 700 hp Hellcat motor in an a-body and hitting the remote starter on the red key in the staging lanes for giggles.
Re: What is the ideal Street/Strip Engine these days? [Re: tabletop390] #2812259
08/23/20 02:46 PM
08/23/20 02:46 PM
my own world
theraif Offline
theraif  Offline
my own world
10 Reasons You’re Better Off With a Big-Block Ford
https://www.hotrod.com/articles/cheap-ford-big-block-460-10-reasons-jon-kaase/
Re: What is the ideal Street/Strip Engine these days? [Re: theraif] #2812267
08/23/20 03:33 PM
08/23/20 03:33 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Leave that crap at YellowBullet.
Re: What is the ideal Street/Strip Engine these days? [Re: Pacnorthcuda] #2812278
08/23/20 04:15 PM
08/23/20 04:15 PM
Superfreak
Superfreak
WHY!!
Are you afraid to talk engines?
Re: What is the ideal Street/Strip Engine these days? [Re: Jamey] #2812307
08/23/20 05:36 PM
08/23/20 05:36 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
[/quote]
I messaged callies this past week and new blocks are right around the corner from what I was told. Their sister company has pics posted on Facebook of new hemi blocks being machined. [/quote]
Well i hope that comes to fruition . There is so many guys who seem to be looking to obtain a stronger base and retain their current program/structures
Tex
New best MPH 130.32
Re: What is the ideal Street/Strip Engine these days? [Re: tex013] #2812317
08/23/20 06:12 PM
08/23/20 06:12 PM
Dragula Offline OP
Dragula  Offline OP
Well that sounds promising....I like their parts.
Re: What is the ideal Street/Strip Engine these days? [Re: Dragula] #2812331
08/23/20 06:42 PM
08/23/20 06:42 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Holley Moparty (mopar version of LS fest)
https://www.moparty.com/
Re: What is the ideal Street/Strip Engine these days? [Re: Dragula] #2812346
08/23/20 07:34 PM
08/23/20 07:34 PM
AndyF Offline
AndyF  Offline
The Hellcrate is still a little more expensive than a 700 hp big block but it isn't a lot more. A 700 hp big block using a factory block and all new parts is usually in the $15,000 range. A Hellcrate is probably close to $20K by the time you buy the front end kit and the install kit plus the various swap parts. A Hellcrate should be more streetable than the average 700 hp big block. Typically a big block will need a roller cam to get into the 700 hp range so then you have some wear issues and a bronze gear and stuff like that. You can build a fairly streetable 700 hp big block with EFI and the correct cam choice but the cost goes up. If you are going to drive the car a lot then the Hellcrate is probably the best choice, especially if you go with the matching transmission.
Re: What is the ideal Street/Strip Engine these days? [Re: AndyF] #2812408
08/23/20 10:23 PM
08/23/20 10:23 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
If I was starting from scratch I would be going with the Gen III Hemi stuff. I don't think we are far off on seeing the aftermarket really get behind it.
I have my money tied up in Dodge R5P7 stuff, which I liquidated my W8 stuff to go over to. I won't be changing any time soon.
Alan Jones
Page 1 of 3 1 2 3
