86 D150 carb troubles #2811966
08/22/20 03:04 PM
08/22/20 03:04 PM
N.J. north west
1972challenger Offline OP
N.J. north west
I have an 86 Ram with a 318 and the carb number is unreadable. It looks like 4324. It's a stock Holley 2 bbl and the truck only has 60 k on it so I doubt it's been changed. I bought a kit from NAPA but most of the parts don't fit. The truck was purchased in PA so I don't think I'm dealing with any Cali emissions. Does anyone know the part numbers for these trucks? How many different carburetors did Dodge use?
Re: 86 D150 carb troubles [Re: 1972challenger] #2811973
08/22/20 03:33 PM
08/22/20 03:33 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What part number kit did you get? Can you post pictures of the carb numbers?
Re: 86 D150 carb troubles [Re: NITROUSN] #2812006
08/22/20 05:48 PM
08/22/20 05:48 PM
N.J. north west
N.J. north west
I'll get some pictures when I'm back in the shop but the sticker disintegrated when I wiped off the grease. I was looking around on NAPA's site and think I found the right kit by looking at the pictures of the gaskets. I'd also like to just dump the 2 bbl and bolt on and Eddy intake and carb.
Re: 86 D150 carb troubles [Re: 1972challenger] #2812011
08/22/20 06:04 PM
08/22/20 06:04 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The number should be stamped in the base as I recall.
Re: 86 D150 carb troubles [Re: NITROUSN] #2812057
08/22/20 08:02 PM
08/22/20 08:02 PM
scratchnfotraction Offline
a simple replacement for the 2v set up is the edelbrock 318/340/360 performer intake with 1405 edelbrock 600cfm or the newer model edelbrock annular dishcharge 600 cfm carb along with the edelbrock mopar throttle lever adaptor.
this will bolt on a 4v intake/carb that hooks right up with the stock throttle/PTK linkage and adjust out properly with a slight adjustment to the 2v carb flat slide bar(I bolt 2 together to correct length).. finding the 4v q-jet PTK linkage for a truck will fit with out mods and also opens you up to a edelbrock RPM air-gap intake and edelbrock carb if you need more for it.
my 85 360 headed 318 has rpm air-gap intake and edelbrock 750cfm carb stock q-jet PTK linkage.
also a stock 4v intake and a mopar q-jet & linkage is what came stock on 4v trucks so that's is a direct stock package on a 360 headed 318 or the 360 engine in trucks.
find the stock intake and you can buy a reman q-jet for the 85 truck about the same price a performance carb runs.
it will work with the small 318 port heads and the edelbrock performer intake is the best fit on those heads as they have a necked down runner for the 318 and requair porting to open them up to 340/360 port size.
a q-jet will fit the edelbrock 318/340/360 performer intake which is even better for a mopar q-jet/linkage set up.
