Re: The Hemi hole
[Re: cudaman1969]
#2811321
08/20/20 09:40 PM
08/20/20 09:40 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Looks like it would be an easy repair for someone competent at working with cast iron. It would not bother me to run it after a repair.
Re: The Hemi hole
[Re: cudaman1969]
#2811404
08/21/20 01:49 AM
08/21/20 01:49 AM
Posts: 43,355 Bend,OR USA
Cab_Burge
Is there any H.D. diesel repair shops close to you? If so take it there and see if they can help you ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) That is how I found out about a cast iron welding shop in SO CA years ago ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) How far is Bob George racing from you? Maybe they can help you also ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
Re: The Hemi hole
[Re: cudaman1969]
#2811407
08/21/20 03:12 AM
08/21/20 03:12 AM
Posts: 3,114 Michigan
A727Tflite
Feel the same, just not sure if I should attempt it myself. I’ve never backed away from trying stuff but this block HAS to be the one I use. I also don’t know of anyone within a thousand mile radius to do it either. Any great welders in the Va area? You’re 600 from me, there isn’t a welder here that does all the farm country diesel repairs, he has done street Hemi manifold repair for men and I have one Hemi block going to him shortly. Every time I have visited I have seen all kinds of gas performance blocks besides all the diesel stuff.
Re: The Hemi hole
[Re: cudaman1969]
#2811450
08/21/20 09:05 AM
08/21/20 09:05 AM
Posts: 5,992 Anoka County, MN
Leigh
Anoka County, MN
Maybe contact Jody Collier, from Welding Tips and Tricks. I seem to remember he’s in the Atlanta area.
