68 RR Sun Visor replacement ?? #2811202
08/20/20 06:20 PM
08/20/20 06:20 PM
Retired now in Tennessee
Chi_Town_Runner Offline OP
Have original sun visors in my 68 RR. Need replacing.
Question on removal?
Do they just slide off?
Do they need to be clocked in a certain position when removing or installing?
I tried sliding them but didn't want to use too much force so as not to bend the rods or dislocate anything 52 years old.
Any hints or suggestions would be appreciated.
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: 68 RR Sun Visor replacement ?? [Re: Chi_Town_Runner] #2811221
08/20/20 07:03 PM
08/20/20 07:03 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
They tend to be on the shafts pretty tight so some effort is required to remove them, Otherwise its pretty straight pull and push job , same goes for the tip end
Re: 68 RR Sun Visor replacement ?? [Re: Chi_Town_Runner] #2811270
08/20/20 08:09 PM
08/20/20 08:09 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I just swapped the ones out of my Cuda and it took way more muscle than I had anticipated. It didn't help one was twisted inside, but toake reassembly easier I took some 2000 grit to smooth out the rods and applied a real light coat of aerosol lubricant. It worked well.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 68 RR Sun Visor replacement ?? [Re: A39Coronet] #2811310
08/20/20 09:11 PM
08/20/20 09:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yeah, it's kinda scary how much effort it takes sometimes; I cheat by squirting a little silicone lube down in there.
Same with the install if necessary, and in that case just a wee bit.
