Re: 1986 New Yorker Bulkhead Connector Wiring
[Re: elmor353]
#2810365
08/18/20 07:49 PM
08/18/20 07:49 PM
Posts: 4,815 Castlegar, BC, Canada
That AMC Guy
Does it restart right after it shuts down or not?
If not, if it'll sit there and crank and crank but no fire, THAT would be an automatic shutdown relay fault.
When tripped, it's supposed to shut down spark and fuel pump.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: poorboy]
#2811271
08/20/20 08:10 PM
08/20/20 08:10 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
I worked at a Chrysler dealership when those cars were new. For it to quit running and not restart is one of the things caused by a faulty distributor hall effect pickup. Has it ever quit while driving down the road? Gene Had this on my Omni. A new pick-up fixed it.
[Re: elmor353]
#2813813
08/27/20 01:26 AM
08/27/20 01:26 AM
That AMC Guy
I've been having a random hiccup with mine that I think I may have solved. Seems on mine there may be a break in one of the wires leading to the MAP sensor. When I push on the wiring, the engine will stumble. And it's repeatable, too. Maybe check your connections / wiring as well.
