Header gaskets #2809753
08/17/20 01:22 PM
08/17/20 01:22 PM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
What are you guys using? I currently have some copper gaskets but they leak. I have Hooker Fenderwell headers and 452 heads. With the Stealth Super Sniper install I want to get the exhaust leaks fixed prior to firing this thing up
eBay-cdwmotorsports
Re: Header gaskets [Re: cdwmotorsports] #2809768
08/17/20 02:02 PM
08/17/20 02:02 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I"ve had good luck with Jegs brand copper gaskets on my 360 and use Mr. Gasket ultra seal gaskets on my 440.
Re: Header gaskets [Re: DusterKid] #2809773
08/17/20 02:11 PM
08/17/20 02:11 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Remflex has alot of praise.
http://catalog.remflex.com/
Keep old mopars alive.
Re: Header gaskets [Re: 2boltmain] #2809797
08/17/20 03:17 PM
08/17/20 03:17 PM
Martinsville, IN
Martinsville, IN
I ordered Remflex and Cometics for the head side and Remflex for the collector side.
eBay-cdwmotorsports
Re: Header gaskets [Re: DusterKid] #2809800
08/17/20 03:18 PM
08/17/20 03:18 PM
Martinsville, IN
Martinsville, IN
I currently have copper gaskets and they are a joke, not sure the brand though
eBay-cdwmotorsports
Re: Header gaskets [Re: cdwmotorsports] #2809851
08/17/20 05:27 PM
08/17/20 05:27 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i have a cometic type , as recommended with the Trickflow heads . Use a little skim orange exhaust silicon been ablle to reuse them several times . Best i have had
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Header gaskets [Re: cdwmotorsports] #2809855
08/17/20 05:45 PM
08/17/20 05:45 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
if --- the heads and headers are true and flat ,
a little permatex red and never a leak here ...
Re: Header gaskets [Re: 2boltmain] #2809893
08/17/20 07:37 PM
08/17/20 07:37 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I have used them 2x.. not cheap but they work
Coming soon!!!!
Re: Header gaskets [Re: cdwmotorsports] #2809904
08/17/20 08:02 PM
08/17/20 08:02 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
How thick are the header flanges? Especially with long fenderwell headers
Re: Header gaskets [Re: nss guy] #2809911
08/17/20 08:16 PM
08/17/20 08:16 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
A thin smear of copper rtv on your copper gaskets and you should be good. Wire brush it off and apply new rtv if you need to take it apart.
Those copper gaskets don't crush at all from my experience. The ones I tried were hard as hell so they are either touching or not touching and not touching is leaking.
Re: Header gaskets [Re: Neil] #2809926
08/17/20 08:43 PM
08/17/20 08:43 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Remflex
Re: Header gaskets [Re: Neil] #2809932
08/17/20 08:57 PM
08/17/20 08:57 PM
Martinsville, IN
Martinsville, IN
This is what I'm experiencing too, I figured they'd be a softer copper to allow for them to crush.
eBay-cdwmotorsports
Re: Header gaskets [Re: nss guy] #2809933
08/17/20 08:59 PM
08/17/20 08:59 PM
Martinsville, IN
Martinsville, IN
Pretty thick, they are 20 year old Hooker Super Comps I'd say 3/8" without going and measuring them
eBay-cdwmotorsports
Re: Header gaskets [Re: cdwmotorsports] #2810026
08/18/20 01:55 AM
08/18/20 01:55 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
FelPro has been good for me with aluminum heads.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Header gaskets [Re: 2boltmain] #2810036
08/18/20 03:28 AM
08/18/20 03:28 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I've used them and have been happy with them. up
Re: Header gaskets [Re: SNK-EYZ] #2810060
08/18/20 08:02 AM
08/18/20 08:02 AM
an8sec70cuda Offline
Never had any luck w/ the copper or aluminum header gaskets.
Just high temp silicone works good if you can easily apply it and pull the header straight onto the mating surface. On most big block stock body cars, you can't really do that.
The tan colored Indy gaskets work real well, but they're for the big port heads.
I've had good luck w/ the Fel-Pro gaskets and I have a set of Remflex gaskets on the way. Figured I'd give them a try since I've heard good things about them.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Header gaskets [Re: an8sec70cuda] #2810072
08/18/20 08:32 AM
08/18/20 08:32 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I agree with just a (thin smear) of silicone if we're talking a manifold or header with a machined flat flange.
I think Hooker has a ground down but -raised- weld bead at each port so not sure if that's flat enough or enough surface area.
Re: Header gaskets [Re: cdwmotorsports] #2810080
08/18/20 09:06 AM
08/18/20 09:06 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I think the issue many times is not the gasket, but the header flange. I personally have had the best luck with the aluminum layer type gasket for sealing and reuse. Hi-temp RTV works if you don't mind it squishing out and looking bad.
But headers with a raised welded ridge on the flange are just junk. I have built the last few sets on my projects, I weld in stubs, and then put them in a mill and flatten them just like an OEM exhaust manifold, then build and attach the tubes. I have had no leaks with any type of gasket.
Re: Header gaskets [Re: jwb123] #2810085
08/18/20 09:15 AM
08/18/20 09:15 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
If the flange is machined flat just a thin smear of rtv works. So thin it's not squishing out everywhere. I prefer Toyota black FIPG.
Re: Header gaskets [Re: INTMD8] #2810121
08/18/20 10:45 AM
08/18/20 10:45 AM
moparx Offline
moparx  Offline
no matter the header brand or gasket used, separate the end tubes from the center tubes [a hacksaw works] and drill one hole on each tube mating flange oversize.
this allows for flexing due to heat, and ensures no leaks.
this even works to seal cheapo brands with thin flanges.
i stole this trick from mr. Pbody years ago. biggrin
beer
