Re: Header gaskets
[Re: cl440]
#2810215
08/18/20 02:40 PM
08/18/20 02:40 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Regardless of any gasket manufacturer or material, the final matter is how the mating surfaces are from the header flange to the gasket. I've seen more poorly designed header flanges that will not allow any gasket to seal, and the RTV eventually will blow through.
Mate the gasket to the header flange and determine if there are passages -- even very slight gaps, such a 1/64" or progressively larger -- for exhaust leakage. Raised ridge/beads are the most concern (example: Hookers). If needed, apply a wide-spread amount of JB-Weld Extreme-Temp putty around header flange, allow one-day to dry, then flat file the surface to be flush... in other words, a wider flange surface that will mate with the gasket. That' what I've done and had excellent success.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
Re: Header gaskets
[Re: n20mstr]
#2810975
08/20/20 08:39 AM
08/20/20 08:39 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Red Sensor safe silicone...…
Best "gaskets" I ever used
LMAO ! I'm not a SBC guy but our endurance car is a GM product. When we were installing the headers I went to get the gaskets, my teammate (ran roundy roundy chevy's a long time) said what are you doing. He grabbed a tube of silicone and said this is all you need. And SOB we have 80+ hours of hard racing and NO leaks.
Re: Header gaskets
[Re: Mr.Yuck]
#2810997
08/20/20 09:33 AM
08/20/20 09:33 AM
Posts: 4,682 On the parachute mount
n20mstr
LMAO ! I'm not a SBC guy but our endurance car is a GM product. When we were installing the headers I went to get the gaskets, my teammate (ran roundy roundy chevy's a long time) said what are you doing. He grabbed a tube of silicone and said this is all you need. And SOB we have 80+ hours of hard racing and NO leaks. I stopped using header gaskets a long time ago....they always leak at the worst time. Red Silicone for the win ! ! !
....BAD A$$ STREET CAR.....
Re: Header gaskets
[Re: n20mstr]
#2811017
08/20/20 10:34 AM
08/20/20 10:34 AM
Posts: 1,412 Johnstown
69dart
Johnstown
I only run the aluminum ones. https://www.jegs.com/i/JEGS/555/212555/10002/-1The only time they blow is if the bolts shake loose. Usually need retightened a few times after install. They are thick so may need slightly longer bolts. I have re-used them up to a half dozen times.
