Rotational torque preload 8-3/4"
#2809517
08/16/20 03:59 PM
08/16/20 03:59 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
All,
I pulled the pumpkin from my 8-3/4" 489 rear. I have the crush sleeve eliminator kit and now I need the "ideal" angular torque figure. Factory manual and Haynes say to compare to the original setting. What if I don't have the original setting?
What's a good setting to "target"?
Thanks!
Re: Rotational torque preload 8-3/4"
[Re: cjskotni]
#2809528
08/16/20 04:29 PM
08/16/20 04:29 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I would use the same factory recommended preload used for non-crush sleeve pinions.
[Re: DoctorDiff]
#2809548
08/16/20 06:08 PM
08/16/20 06:08 PM
Posts: 11,570 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The Randy's book is probably the best as far as information for most rears, patterns, specs, etc.
On a drag race unit with standard roller bearings, I keep the turning torque on the pinion to the low limit or maybe a little lighter, depending on what it's being used in. And only add a few lb.in. to the total with the carrier bearings. Something that will be driven on the street and need to go some miles, I'll go a little closer to middle of the spec.
[Re: cjskotni]
#2809615
08/16/20 10:30 PM
08/16/20 10:30 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
The FSM differ on the amount of inch lb. torque rotational torque on the "489" case due to the pinion seal being in place, all the other torque specs say without that seal I would use .010 to .020 with the seal on used pinion bearings and from 20 to30 inch lbs. on new bearings with the seal with no carrier in place Don't for get to check rotating it both ways
