Is this from a Charger or Coronet? #2809446
08/16/20 11:44 AM
08/16/20 11:44 AM
BRIDGEWATER, CT.
WINGNUT Offline OP
WINGNUT  Offline OP
BRIDGEWATER, CT.
Got this fender splash shied with a bunch of parts from a friend. What does it fit? TIA, WINGNUT
Re: Is this from a Charger or Coronet? [Re: WINGNUT] #2809554
08/16/20 06:42 PM
08/16/20 06:42 PM
Omaha
road Offline
road  Offline
Omaha
I was told it is for a charger. I have the same one. From what i have found so far, they are not reproduced. Checked the parts manuals and not finding a part number. If you get additional info, PM me. Thanks
Re: Is this from a Charger or Coronet? [Re: road] #2809831
08/17/20 04:22 PM
08/17/20 04:22 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'm about 99% sure its not Coronet. As I don't think They were a separate piece.
I'm pretty sure Charger is the only one that's a separate piece like shown
BUT< I may be wrong
Re: Is this from a Charger or Coronet? [Re: gtx6970] #2809901
08/17/20 07:59 PM
08/17/20 07:59 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
What year Charger ??
Re: Is this from a Charger or Coronet? [Re: TJP] #2809951
08/17/20 09:30 PM
08/17/20 09:30 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Here are mine 1969 Charger.
Re: Is this from a Charger or Coronet? [Re: NITROUSN] #2810116
08/18/20 10:29 AM
08/18/20 10:29 AM
moparx Offline
moparx  Offline
where do those panels go ?
i think my charger is missing them. are they really needed ?
beer
Re: Is this from a Charger or Coronet? [Re: TJP] #2810297
08/18/20 06:21 PM
08/18/20 06:21 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Pretty sure 1968 and 1969 only
Re: Is this from a Charger or Coronet? [Re: moparx] #2810305
08/18/20 06:25 PM
08/18/20 06:25 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
beer
Look up inside the front fender well , forward of the tires. along the top of the fender.
Goes behind behind the headlights so to speak, and have a rubber flap attached to them .
Typical B bodies the rubber flap attaches directly to the forward fender
Like so
Im not 100% positive the other B body cars used a separate shield like shown
Re: Is this from a Charger or Coronet? [Re: gtx6970] #2810642
08/19/20 12:58 PM
08/19/20 12:58 PM
moparx Offline
moparx  Offline
thank you sir !
i forgot about those being used with the rubber flap.
they are intended to keep dirt and junk from getting into the cavity under the forward fender top, therefore most definitely needed.
unfortunately, they can also trap dirt and moisture there, causing the fender to rot.
mine are in the trunk of my car with the rubber seals still attached. they were taken off because the part of the seal that touches the engine side of the driver's fender had collected enough junk over the years that there is a 1" square hole that needs repaired due to rust.
beer
Re: Is this from a Charger or Coronet? [Re: moparx] #2812342
08/23/20 07:19 PM
08/23/20 07:19 PM
BRIDGEWATER, CT.
WINGNUT Offline OP
WINGNUT  Offline OP
BRIDGEWATER, CT.
Thanks guys! Looks like I have a passenger side with a few small rust holes. Still usable. Fits 68 and 69. Since hey don't reproduce them, what is it worth? WINGNUT
