Re: Iron vs. Aluminum block? [Re: RATTRAP] #2808793
08/14/20 10:39 AM
08/14/20 10:39 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Ill take the weight loss over the HP loss any day. As noted aluminum blocks can be made better to more even out those differences. Being Hipped and hot honed are two things that can help make a better foundation.
Re: Iron vs. Aluminum block? [Re: Al_Alguire] #2809174
08/15/20 11:12 AM
08/15/20 11:12 AM
MN
JERICOGTX Offline OP
MN
Well I scored a deal on a used INDY RB block. Would have preferred a low deck, but for what I paid, and got with it, I couldn’t turn it down. The block was run in a dragster, and has been refreshed a couple times. On the last refresh a rod bolt broke on the 202 pass, and the Oliver rod hit the pan rail, and bent in the shape of a horseshoe, but did not break. The guy even reused the crank, and is still running it. With the block, I got 6 Diamond pistons, and 4 Oliver rods 7.100 length. It had a 4.375 stroke crank in it, and I’ll go that way again. I’m basically going to build a duplicate of how it was before, as he ran SR heads just like mine.
DEEF7085-488B-4C6D-9BAF-FD55EAAC97DF.jpeg3D21E99B-6982-432C-9986-800BE245C90A.jpeg81252DD3-D704-48CD-989B-1178C2AFE8F0.jpeg32CC79D3-6D6D-4BA6-9429-7CABB5165329.jpeg
69 GTX 68 Road Runner
Re: Iron vs. Aluminum block? [Re: JERICOGTX] #2809176
08/15/20 11:24 AM
08/15/20 11:24 AM
tboomer Online work
tboomer  Online Work
The wife saw that on farcebook this morning Jeff...Cool.
Re: Iron vs. Aluminum block? [Re: tboomer] #2809180
08/15/20 11:35 AM
08/15/20 11:35 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Be careful with the repair on this. That looks pretty straight forward but notice the cracking going back to the cap bolts? Up and over the pan rail? LOOKS like the crack also extends further up into the skirt that it first appears. Could just be the photo. NOT saying it cannot be fixed but perhaps more than it appears. Interesting that I fixed a NON windowed Indy block about a year ago that was cracked very similarly.
Todd
Re: Iron vs. Aluminum block? [Re: JERICOGTX] #2809186
08/15/20 11:47 AM
08/15/20 11:47 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I have a set of 4.5 pistons that I would sell. 6.76 Eagle rods too, both for a 4.15 crank. I need 4.53 pistons.
Re: Iron vs. Aluminum block? [Re: JERICOGTX] #2809193
08/15/20 11:56 AM
08/15/20 11:56 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Just for info, I went from a 528 Mega block (steel rods), to a 572 KB (steel rods) and the car weighed 70lbs less.Then went from the 572 to a 655 Indy block (alloy rods) with T/R and the car weighed 30lb more.
Re: Iron vs. Aluminum block? [Re: sasquatch] #2809208
08/15/20 12:35 PM
08/15/20 12:35 PM
MN
MN
Todd
Todd, I have the dyes and stuff needed for checking the cracks. This is a long term project, and I’m in no rush to build it. I can have it welded by a coworker, that is one of the best welders I’ve met. Him and I discussed it before I bought it. Even if it ends up as a coffee table stand, I have next to nothing into it.
Re: Iron vs. Aluminum block? [Re: JERICOGTX] #2809279
08/15/20 03:42 PM
08/15/20 03:42 PM
New York
polyspheric Online content
polyspheric  Online Content
New York
I remember reading somewhere about welding an aluminum casting, but no results.
To locate the stop drill hole: it should be (obviously) in line with the crack, but 1 drill diameter farther into the "good" material after the visible end of the crack. Sounds like anticipating the crack has an effect under the surface?
Anyone heard of this?
Boffin Emeritus
Re: Iron vs. Aluminum block? [Re: tboomer] #2809317
08/15/20 08:22 PM
08/15/20 08:22 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Did you get the broken piece with the engine?
My mega block thread went south fairly quickly.
Re: Iron vs. Aluminum block? [Re: Sammy] #2809323
08/15/20 09:16 PM
08/15/20 09:16 PM
MN
MN
No broken pieces. I can have a piece CNC made at work to fit.
Re: Iron vs. Aluminum block? [Re: JERICOGTX] #2809340
08/15/20 10:47 PM
08/15/20 10:47 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Todd
If you not going to use it ? ? Let me know I might buy it off you
....BAD A$$ STREET CAR.....
Re: Iron vs. Aluminum block? [Re: n20mstr] #2809396
08/16/20 09:05 AM
08/16/20 09:05 AM
gregsdart Online content
gregsdart  Online Content
Great score on the block and parts Jeff. Since you aren't planning on pushing it real hard, i am optimistic on any power loss being insignificant. But wieght transfer due to losing all that wieght up front is a big deal. I see the combo as a great improvement.
Re: Iron vs. Aluminum block? [Re: JERICOGTX] #2809472
08/16/20 12:52 PM
08/16/20 12:52 PM
central il.
second 70 Offline
second 70  Offline
central il.
Todd
Gee Jeff this sounds more like a Joel bargain.
Re: Iron vs. Aluminum block? [Re: second 70] #2809477
08/16/20 01:04 PM
08/16/20 01:04 PM
MN
MN
Todd
Joel was the first person I called on my way home from picking it up. Had to tell him I finally know how it feels to get a “Joel deal”.
Greg, I bought the block from Bruce K. It’s one he ran in his dragster. He said it was just faster to buy a new block vs. fixing this one. Gene Pearson does his machine work. I trust both of them, that it’s still a decent block.
Re: Iron vs. Aluminum block? [Re: polyspheric] #2809503
08/16/20 02:46 PM
08/16/20 02:46 PM
moparx Offline
moparx  Offline
yes. this is the same for all materials that need crack repair.
a generous V on both sides of the crack [if possible] is also necessary for an adequate repair.
avoid grinding the weld as well. [unless absolutely necessary !]
beer
Re: Iron vs. Aluminum block? [Re: moparx] #2810054
08/18/20 07:39 AM
08/18/20 07:39 AM
MN
MN
Dropped the block off at the machinist yesterday, and he said the block is a simple fix. Looks like I'll be building a 562ci engine now.
