Re: Spark plugs for TF270s?
[Re: PolyDart]
#2808499
08/13/20 03:25 PM
08/13/20 03:25 PM
Posts: 30,995 Oregon
AndyF
Which spark plugs are you running in Trick Flow 270s with about 10.5:1 compression? It's on a 512 low deck. 10.5 compression pump gas street engine I'd use NGK 6987. If it is a race engine or boosted or something else then you might want to go a step colder or tighten the gap.
[Re: AndyF]
#2808690
08/13/20 11:21 PM
08/13/20 11:21 PM
Posts: 876 Arizona
PolyDart
Arizona
Thank you Andy. It's a naturally aspirated pump gas engine.
[Re: PolyDart]
#2808709
08/14/20 01:15 AM
08/14/20 01:15 AM
AndyF
Thank you Andy. It's a naturally aspirated pump gas engine. NGK makes at least 10 plugs in the 6 heat range that will fit those heads so you have lots of choices. Summit carries most of them but buying from NGK direct is usually cheaper than Summit.
[Re: AndyF]
#2808714
08/14/20 01:57 AM
08/14/20 01:57 AM
Posts: 2,458 Sydney,Australia
tex013
Sydney,Australia
i use NGK BKR6E plugs in mine .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2808852
08/14/20 01:19 PM
08/14/20 01:19 PM
AndyF
Tex That is basically the same plug with a tighter gap. That plug has an 031 gap while the 6987 has a 043 gap. Otherwise the specs are the same.
