Walbro Fuel Pump #2806777
08/09/20 09:55 AM
08/09/20 09:55 AM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Has anyone used a Walbro high pressure fuel pump on their conversion? I used an expensive pump that is very loud. I put a 5.7 in a 64 Savoy wagon. Because the wagon tank stands up in the quarter panel, I can't put the pump in the tank. I built an insulated sound inclosure for the pump, mounted it behind the left rear spring hanger, and it is still too loud.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Walbro Fuel Pump [Re: rattler] #2806816
08/09/20 12:00 PM
08/09/20 12:00 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have this intank Walbro pump, quiet as a mouse, this one moves a lot of fuel, they have many choices.
CLICK HERE
Re: Walbro Fuel Pump [Re: CSK] #2806902
08/09/20 03:16 PM
08/09/20 03:16 PM
IL
furious70 Offline
furious70  Offline
IL
I just bought a tanks inc setup for my Coronet 5.7 conversion, will be a long time before I see how quiet that is. I have a walbro 255 hanging off the frame rail on my 70 Fury (EFI, turbo) and that thing gets loud after running for a few hours down the road. Don't really hear it in the car, but if you're outside the car standing next to it you definitely know it's there. Been that way since 2009 no issue.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Walbro Fuel Pump [Re: furious70] #2806938
08/09/20 04:30 PM
08/09/20 04:30 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I had the 255lph intank when I was still carbed & it was loud, this big pump you can hear the fuel flowing through the bypass regulator at an idle,
Re: Walbro Fuel Pump [Re: CSK] #2807158
08/10/20 07:37 AM
08/10/20 07:37 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I run a Walboro/TI GSL392(I think) 255LPH external pump. Good pump, reasonably quite, reliable.
Lots of fakes out there, make sure you buy from a reputable vendor. I paid a little more and got mine from DIYAutotune and not amazon.
68 Barracuda Formula S 340
Re: Walbro Fuel Pump [Re: rattler] #2807240
08/10/20 12:02 PM
08/10/20 12:02 PM
NH, USA
toddinNH Online content
Egghead
toddinNH  Online Content
Egghead
NH, USA
I use the genuine 255lph pumps on.my bikes. I used to work for a European car manufacturer, and we bought them both direct from Walbro and via a major auto parts importer.
They work well enough, but the Bosch "044" pump flows both more at no head pressure, and far more at actual running pressures.
We were buying the Bosch pumps direct for 17USD in 2009 - when we last bought them.
My job was to act as a liaison between global parts suppliers and the warranty needs of the end user(new car buyer). I was so good at my job the company left the US market in 2009. The latter sentence is a joke, but the former beset me with a short-term crisis.
Shorter: the Bosch 044 should support 700 hp, and the Walbro 255 lph somewhat less. Both pumps are widely used and highly regarded. Use with confidence and watch for counterfeits.
Re: Walbro Fuel Pump [Re: toddinNH] #2807547
08/11/20 06:05 AM
08/11/20 06:05 AM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Thanks for the replies. I may change to the Walbro. As I said earlier, I can,t run an in-tank pump due to the lay out of the stock wagon tank. The pump I am running now can be heard at least 50 feet from the car, stupid loud.
Re: Walbro Fuel Pump [Re: rattler] #2807555
08/11/20 07:23 AM
08/11/20 07:23 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
How is the wagon tank configured?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Walbro Fuel Pump [Re: rattler] #2807557
08/11/20 07:25 AM
08/11/20 07:25 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If I turn both of my 255 pumps on you can't hear them from 50ft away lol, whatever pump that is it needs to go.
Re: Walbro Fuel Pump [Re: GoodysGotaCuda] #2808616
08/13/20 07:56 PM
08/13/20 07:56 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
The wagon tanks are stood on edge in the left quarter panel behind the tire.
Re: Walbro Fuel Pump [Re: rattler] #2808730
08/14/20 07:37 AM
08/14/20 07:37 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Depending on the opening, you may be able to sneak a pump on the end of the stock sending unit. A friend of mine did that on a in-cab C10 fuel tank.
2020 RAM 1500
Re: Walbro Fuel Pump [Re: GoodysGotaCuda] #2808731
08/14/20 07:45 AM
08/14/20 07:45 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That with a small hydramat might do the trick.
Re: Walbro Fuel Pump [Re: Bad340fish] #2809608
08/16/20 10:12 PM
08/16/20 10:12 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I'm using a GSL392 that shipped with the Holley Sniper Master kit.
https://walbrofuelpumps.com/walbro-gsl392-inline-fuel-255lph-pump.html.html
I can hear it when the system primes, but not with the motor running from inside or outside the car.
Re: Walbro Fuel Pump [Re: MarkZ] #2812183
08/23/20 10:13 AM
08/23/20 10:13 AM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Thanks, I ordered a Walbro. We'll see how it does.
Re: Walbro Fuel Pump [Re: rattler] #2813293
08/25/20 09:33 PM
08/25/20 09:33 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
I got the Walbro pump installed today. I can't believe how quite it is. Wish I had bought it first.
