Simple green bearing install question
#2807820
08/11/20 06:20 PM
08/11/20 06:20 PM
Posts: 253 Iceland
BadMoonRacer
Iceland
Regarding the locking ring/snap ring supplied. Is it to be located on the inside of the brake backing plate (between the axle housing and the brake backing plate) or outside (between the retainer and the brake backing plate)? I am betting on the former, but want to be absolutely sure (unit has stock drums).
Thanks for replying
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials. Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: Simple green bearing install question
[Re: BadMoonRacer]
#2807823
08/11/20 06:27 PM
08/11/20 06:27 PM
Posts: 1,980 USA
Suregrip391
USA
Does this help...snap ring towards axle flange, o’rings get inserted into axle housing first.
[Re: Cab_Burge]
#2807926
08/12/20 03:27 AM
08/12/20 03:27 AM
Posts: 253 Iceland
BadMoonRacer
Iceland
Thanks for replying, gentlemen,
Sure grip391; You mean that the snap ring should be behind the brake backing plate (on the axle housing side or inside of that plate)? Cab: You mean that the snap ring is to be on the outside of the brake backing plate? I am still confused. I wrote dr diff this morning for clarification. Don´t know when they will reply, so if any of you is absolutely sure of where the snap ring should be, please don´t hestitate to write a reply.
[Re: BadMoonRacer]
#2807928
08/12/20 03:41 AM
08/12/20 03:41 AM
Posts: 1,980 USA
Suregrip391
USA
Have the bearing pressed on as shown in my pic. Snap ring facing down. O’ring up. I got these axles from DoctorDiff.
[Re: Suregrip391]
#2807933
08/12/20 04:49 AM
08/12/20 04:49 AM
Posts: 253 Iceland
BadMoonRacer
Iceland
Suregrip391 thanks for your input. I have already pressed the bearing on to the axle in the correct manner. The issue here is not in which order the snap ring and the O ring sit on the bearing; it is only if the location of the snap ring should be inside or outside of the brake backing plate when mating the axle shaft into the housing.
[Re: Suregrip391]
#2807939
08/12/20 05:12 AM
08/12/20 05:12 AM
Posts: 1,980 USA
Suregrip391
USA
And installed.....
[Re: Suregrip391]
#2808052
08/12/20 11:03 AM
08/12/20 11:03 AM
Posts: 253 Iceland
BadMoonRacer
Iceland
Doctor Diff has replied to my question:
"The snap-ring installs against the outside surface of the drum brake backing plate. In other words, the backing plate does not double as a wheel bearing retainer. Don't forget to place the special fiber gasket around the snap ring between the backing plate and 5-hole retainer."
Thanks to those who responded on Moparts.
Ragnar
