Simple green bearing install question #2807820
08/11/20 07:20 PM
08/11/20 07:20 PM
Iceland
BadMoonRacer Offline OP
Iceland
Regarding the locking ring/snap ring supplied. Is it to be located on the inside of the brake backing plate (between the axle housing and the brake backing plate) or outside (between the retainer and the brake backing plate)?
I am betting on the former, but want to be absolutely sure (unit has stock drums).
Thanks for replying
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials.
Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: Simple green bearing install question [Re: BadMoonRacer] #2807823
08/11/20 07:27 PM
08/11/20 07:27 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
Does this help...snap ring towards axle flange, o’rings get inserted into axle housing first.
Re: Simple green bearing install question [Re: Suregrip391] #2807858
08/11/20 09:20 PM
08/11/20 09:20 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
So, you are saying axle flange, brake backing plate, snap ring, then retainer?
Re: Simple green bearing install question [Re: BadMoonRacer] #2807912
08/11/20 11:52 PM
08/11/20 11:52 PM
Install one axle housing gasket then the backing plate and then the axle with another gasket between the backing plate and axle retainer between the snap ring and the axle end and then tighten the 5 retaining nuts down up wrench
It has been a while since I've install a axle so when in doubt call, contact the company you bought them from for their proper instructions scope
Re: Simple green bearing install question [Re: Cab_Burge] #2807926
08/12/20 04:27 AM
08/12/20 04:27 AM
Iceland
Iceland
Thanks for replying, gentlemen,
Sure grip391; You mean that the snap ring should be behind the brake backing plate (on the axle housing side or inside of that plate)?
Cab: You mean that the snap ring is to be on the outside of the brake backing plate?
I am still confused.
I wrote dr diff this morning for clarification. Don´t know when they will reply, so if any of you is absolutely sure of where the snap ring should be, please don´t hestitate to write a reply.
Re: Simple green bearing install question [Re: BadMoonRacer] #2807928
08/12/20 04:41 AM
08/12/20 04:41 AM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
Have the bearing pressed on as shown in my pic. Snap ring facing down. O’ring up. I got these axles from DoctorDiff.
Re: Simple green bearing install question [Re: Suregrip391] #2807933
08/12/20 05:49 AM
08/12/20 05:49 AM
Iceland
Iceland
Suregrip391 thanks for your input. I have already pressed the bearing on to the axle in the correct manner.
The issue here is not in which order the snap ring and the O ring sit on the bearing; it is only if the location of the snap ring should be inside or outside of the brake backing plate when mating the axle shaft into the housing.
Re: Simple green bearing install question [Re: BadMoonRacer] #2807938
08/12/20 06:12 AM
08/12/20 06:12 AM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
I’m pretty sure it’s inside the housing resting on the lip. Since I don’t fully understand, Ill bow out and let a pro answer this. I’ll attach some pics of what mine looks like in case it helps. Sorry....
Re: Simple green bearing install question [Re: Suregrip391] #2807939
08/12/20 06:12 AM
08/12/20 06:12 AM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
And installed.....
Re: Simple green bearing install question [Re: Suregrip391] #2807940
08/12/20 06:15 AM
08/12/20 06:15 AM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
Also, don’t forget To use the fibre looking gasket between the brake backing plate and 5-hole wheel bearing retainer, it comes with the bearings. If you don’t, the retainer will bend over the snap-ring.
Re: Simple green bearing install question [Re: Suregrip391] #2808052
08/12/20 12:03 PM
08/12/20 12:03 PM
Iceland
Iceland
Doctor Diff has replied to my question:
"The snap-ring installs against the outside surface of the drum brake backing plate. In other words, the backing plate does not double as a wheel bearing retainer. Don't forget to place the special fiber gasket around the snap ring between the backing plate and 5-hole retainer."
Thanks to those who responded on Moparts.
Ragnar
