New best tonight! #2806379
08/08/20 12:20 AM
08/08/20 12:20 AM
W. Kentucky
justinp61 Offline OP
W. Kentucky
I've been saying since I built my 434" small block that I thought it should run 6.30's and tonight it did! 69 Dart, 3350#, pump 93, 6.33 @ 108.42 mph, 1.40 60'. It started out pretty hot but finally cooled down, about 20 minutes after the run it was 68°, 94.4% R.H., 30.19" B.P., D.A. 649'.
I'm pleased with the run and feel if I can get the 60' down it may run in the high .20's.
Re: New best tonight! [Re: justinp61] #2806426
08/08/20 06:55 AM
08/08/20 06:55 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Congratulations!
Re: New best tonight! [Re: slantzilla] #2806428
08/08/20 07:02 AM
08/08/20 07:02 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That is always a good feeling, congrats.
68 Barracuda Formula S 340
Re: New best tonight! [Re: Bad340fish] #2806432
08/08/20 07:15 AM
08/08/20 07:15 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Congrats Justin!
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: New best tonight! [Re: justinp61] #2806437
08/08/20 07:50 AM
08/08/20 07:50 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Very nice. up
Re: New best tonight! [Re: BSB67] #2806439
08/08/20 08:05 AM
08/08/20 08:05 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Very nice. Congratulations
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: New best tonight! [Re: pittsburghracer] #2806462
08/08/20 09:25 AM
08/08/20 09:25 AM
W. Kentucky
W. Kentucky
Thanks guys. up
I only got to make three passes, a guy in a boosted Vette pushed out a head gasket and put anti freeze down and it took forever to clean up.
The first pass the car felt like the front end was raising then unloading the tires, this happened four or five times. I tightened the rebound on the front shocks two clicks and went back this time I tried the trans break, that was a mistake. This CRT brake has never been right in first, in second gear it woks great. Anyway I turned on the stage lights, hit the button and came up on the two step, the car bumped forward and red lit, then blew the tires off on the hit.
Before the 6.33 pass I tightened the rebound on the rear shocks two clicks. My buddy was in the water box and said the car said the car left clean and went straight down the track.
I'm looking forward to see what it'll do in the 1/4 at Bowling Green next month. drive
Re: New best tonight! [Re: justinp61] #2806654
08/08/20 06:15 PM
08/08/20 06:15 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Congrats on the new best !!!!
Looks like an Ohio Valley time slip??
My sister lives about 15 miles from there
....BAD A$$ STREET CAR.....
Re: New best tonight! [Re: n20mstr] #2806671
08/08/20 07:17 PM
08/08/20 07:17 PM
W. Kentucky
W. Kentucky
Thanks.
Beacon Dragway, Paducah.
Re: New best tonight! [Re: justinp61] #2806725
08/09/20 12:05 AM
08/09/20 12:05 AM
gregsdart Offline
gregsdart  Offline
Impressive👍👍 on pump gas no less👍
Re: New best tonight! [Re: gregsdart] #2806734
08/09/20 03:25 AM
08/09/20 03:25 AM
Louisiana
Red440 Offline
Red440  Offline
Louisiana
Thats great news ! Happy for you , hard work paying off. congrats.
Re: New best tonight! [Re: Red440] #2806745
08/09/20 07:24 AM
08/09/20 07:24 AM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
6.30 anything is moving. Congrats , Best my 422 has been so far is 6.51 with a 1.40 60' time. That 108 is moving.
6.50 @105.26
Re: New best tonight! [Re: Kindafast] #2807184
08/10/20 09:57 AM
08/10/20 09:57 AM
an8sec70cuda Offline
Very nice! That's easy 9 sec in the 1/4.
CHIP
'06 GMC 2500HD LBZ Duramax
