New best tonight!
#2806379
08/08/20 12:20 AM
08/08/20 12:20 AM
Posts: 11,678 W. Kentucky
justinp61
W. Kentucky
I've been saying since I built my 434" small block that I thought it should run 6.30's and tonight it did! 69 Dart, 3350#, pump 93, 6.33 @ 108.42 mph, 1.40 60'. It started out pretty hot but finally cooled down, about 20 minutes after the run it was 68°, 94.4% R.H., 30.19" B.P., D.A. 649'.
I'm pleased with the run and feel if I can get the 60' down it may run in the high .20's.
Re: New best tonight!
[Re: slantzilla]
#2806428
08/08/20 07:02 AM
08/08/20 07:02 AM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
That is always a good feeling, congrats.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: BSB67]
#2806439
08/08/20 08:05 AM
08/08/20 08:05 AM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Very nice. Congratulations
[Re: pittsburghracer]
#2806462
08/08/20 09:25 AM
08/08/20 09:25 AM
justinp61
W. Kentucky
Thanks guys. I only got to make three passes, a guy in a boosted Vette pushed out a head gasket and put anti freeze down and it took forever to clean up. The first pass the car felt like the front end was raising then unloading the tires, this happened four or five times. I tightened the rebound on the front shocks two clicks and went back this time I tried the trans break, that was a mistake. This CRT brake has never been right in first, in second gear it woks great. Anyway I turned on the stage lights, hit the button and came up on the two step, the car bumped forward and red lit, then blew the tires off on the hit. Before the 6.33 pass I tightened the rebound on the rear shocks two clicks. My buddy was in the water box and said the car said the car left clean and went straight down the track. I'm looking forward to see what it'll do in the 1/4 at Bowling Green next month.
[Re: n20mstr]
#2806671
08/08/20 07:17 PM
08/08/20 07:17 PM
justinp61
W. Kentucky
Congrats on the new best !!!!
Looks like an Ohio Valley time slip??
My sister lives about 15 miles from there
Thanks. Beacon Dragway, Paducah.
[Re: Red440]
#2806745
08/09/20 07:24 AM
08/09/20 07:24 AM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
6.30 anything is moving. Congrats , Best my 422 has been so far is 6.51 with a 1.40 60' time. That 108 is moving.
6.50 @105.26
[Re: Kindafast]
#2807184
08/10/20 09:57 AM
08/10/20 09:57 AM
Posts: 13,319 Marion, South Carolina [><]
an8sec70cuda
Very nice! That's easy 9 sec in the 1/4.
