SixPack Intake Questions #2806230
08/07/20 05:46 PM
08/07/20 05:46 PM
Shopping @ HoBo Fright
340SIX Offline OP
Doc Flappergas's Evil Twin
340SIX  Offline OP
How long are the carburetor bolts? 5/16x1"?
And is the vacuum port I assume is 3/8 NPT with 3/8 nipple for 3/8 Hose?
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: SixPack Intake Questions [Re: 340SIX] #2806485
08/08/20 10:16 AM
08/08/20 10:16 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
First off what "sixpack" manifold? A,B,RB,HEMI, early/late? Edelbrock, Weiand, Offy? factory in-line style, tunnel ram style, STR? lots to chose from?
Re: SixPack Intake Questions [Re: DAYCLONA] #2806591
08/08/20 03:07 PM
08/08/20 03:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Why would the bolts that attach the carb flange to the manifold differ with engine/brand?
Yes, 5/16" X 1" should be fine. Pretty sure the vacuum fitting is 3/8" NPT
Re: SixPack Intake Questions [Re: John_Kunkel] #2806668
08/08/20 07:12 PM
08/08/20 07:12 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The six pack carb bolts I have are 1.125 if my memory’s correct. They have the “H” bolt.
Re: SixPack Intake Questions [Re: fastmark] #2807006
08/09/20 07:17 PM
08/09/20 07:17 PM
340SIX Offline OP
340SIX  Offline OP
Thanks I have some like that but the finish is bad.
I assume no washers under them. Mine are 1.25" long.
Re: SixPack Intake Questions [Re: 340SIX] #2807172
08/10/20 08:57 AM
08/10/20 08:57 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
No washers. I’ll measure again to make certain.
Re: SixPack Intake Questions [Re: fastmark] #2807196
08/10/20 10:28 AM
08/10/20 10:28 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I dug out one from my 70 Superbird with a cast iron Manifold. It’s the same measured with a dial caliper is 1.095. It’s the same as the bolt I posted which cam off of a 69 A12 or an AAR cuda oem.
Re: SixPack Intake Questions [Re: fastmark] #2807577
08/11/20 08:32 AM
08/11/20 08:32 AM
VA
dragon slayer Offline
VA
H bolts I have seen are 1 1/8", but I have also seen RSC head markings at 1 1/4". Not saying the RSC was used on a 6 pack though.
Re: SixPack Intake Questions [Re: dragon slayer] #2807587
08/11/20 09:31 AM
08/11/20 09:31 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Maybe with Al. they wanted more thread engagement, I think I would.
Joe
Re: SixPack Intake Questions [Re: jlatessa] #2807612
08/11/20 10:39 AM
08/11/20 10:39 AM
Ohio
B5TA Offline
B5TA  Offline
Ohio
Not to Hi-jack, but what is the best gasket to use? ( carb to intake ) plus if gasket is thicker would that change the length of the bolt needed? Thanks, Kevin
Re: SixPack Intake Questions [Re: B5TA] #2807618
08/11/20 11:13 AM
08/11/20 11:13 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The only gasket I'll use is the tan 1/16" thick O.E.M. cardboard gasket,if the carb base is not 100% flat,the paper thin black gasket will "usually" leak and they are a b#tch to get off the carb base if they have been there a long time.There are a few aftermarket gaskets that I understand are very good but I have never had any experience with them.
Re: SixPack Intake Questions [Re: 62maxwgn] #2807679
08/11/20 01:24 PM
08/11/20 01:24 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Most all of my intakes are aluminum and that’s where all of these come from except my one cast iron Superbird. They are all the same length. I just bought some gaskets from Superperformance and they look nice and thick. I’ve yet to bolt them up on this car.
