SixPack Intake Questions
#2806230
08/07/20 05:46 PM
08/07/20 05:46 PM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
How long are the carburetor bolts? 5/16x1"? And is the vacuum port I assume is 3/8 NPT with 3/8 nipple for 3/8 Hose?
Re: SixPack Intake Questions
[Re: 340SIX]
#2806485
08/08/20 10:16 AM
08/08/20 10:16 AM
Posts: 18,157 Mass
DAYCLONA
Mass
How long are the carburetor bolts? 5/16x1"? And is the vacuum port I assume is 3/8 NPT with 3/8 nipple for 3/8 Hose? First off what "sixpack" manifold? A,B,RB,HEMI, early/late? Edelbrock, Weiand, Offy? factory in-line style, tunnel ram style, STR? lots to chose from?
[Re: DAYCLONA]
#2806591
08/08/20 03:07 PM
08/08/20 03:07 PM
Posts: 25,720 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Why would the bolts that attach the carb flange to the manifold differ with engine/brand?
Yes, 5/16" X 1" should be fine. Pretty sure the vacuum fitting is 3/8" NPT
[Re: John_Kunkel]
#2806668
08/08/20 07:12 PM
08/08/20 07:12 PM
Posts: 6,378 Abilene, Texas
fastmark
Abilene, Texas
The six pack carb bolts I have are 1.125 if my memory’s correct. They have the “H” bolt.
[Re: fastmark]
#2807006
08/09/20 07:17 PM
08/09/20 07:17 PM
340SIX
The six pack carb bolts I have are 1.125 if my memory’s correct. They have the “H” bolt. Thanks I have some like that but the finish is bad. I assume no washers under them. Mine are 1.25" long.
[Re: 340SIX]
#2807172
08/10/20 08:57 AM
08/10/20 08:57 AM
fastmark
Abilene, Texas
The six pack carb bolts I have are 1.125 if my memory’s correct. They have the “H” bolt. Thanks I have some like that but the finish is bad. I assume no washers under them. Mine are 1.25" long. No washers. I’ll measure again to make certain.
