low deck main bearing ?? #280522
04/07/09 04:40 PM
04/07/09 04:40 PM
A Banana Republic near you.
JohnRR Offline OP
JohnRR  Offline OP
are the large thrust flange bearings no longer available ?
Re: low deck main bearing ?? [Re: JohnRR] #280523
04/07/09 08:34 PM
04/07/09 08:34 PM
Arizona
Chris'sBarracuda Offline
Arizona
Re: low deck main bearing ?? [Re: Chris'sBarracuda] #280524
04/08/09 12:23 AM
04/08/09 12:23 AM
JohnRR Offline OP
JohnRR  Offline OP
Check here..
http://www.440source.com/bearings.htm
you just did that to bust my chops I assume?
As much as it pained me to click the link I did ...
NOTHING ...
But thanks for the reply ...
I got a number , maybe obsolete , Clevite MS879P ? but can't find info .. or a set ???
AGAIN the aftermarket has HEADINRECTUMITIS when it comes to the LOW DECK Mopar big block
Re: low deck main bearing ?? [Re: JohnRR] #280525
04/08/09 01:42 AM
04/08/09 01:42 AM
Arizona
Arizona
No, honestly I didn't..
That part # is the only one left I'm afraid..
Check here.... They say the same thing..
http://www.indyheads.com/images/p_pge/price21.pdf
Chris..
