Worn out engine - WWYD?
#2805184
08/04/20 08:39 PM
08/04/20 08:39 PM
Posts: 19,871 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
My 82 F250 has low oil pressure. When hot, I have about 30 lbs at speed, and it drops to near 0 lbs at idle. The truck otherwise runs great. Decent power, no noises, only 1 minor fluid leak...the rear main seal, which is how I found out the crank bearings are worn. The truck is rock solid, and is in otherwise excellent mechanical condition as well. Tires, brakes, hoses, belts, battery, etc. are all new or in like-new condition. It needs zero maintenance items. Every light, switch, gauge, dual tanks, etc. works perfectly. Clutch has 35k on it. AC is inop, but I don't know why, and don't care. The paint sucks. The door panels are shot, but the rest of the interior is pretty nice. I only drive it about 2,000 miles/year. I've had it on several hour+ freeway trips like this without any problems. No problems driving around town, either. I've got about $4,400 in the truck as it sits, including what I paid for it. I've got 3 options: A) have the existing 400 rebuilt B) swap in a reman 400 C) drive it and hope it doesn't blow up, and if it does, either sell it, or revert to one of the first 2 options. No interest in changing to a different engine, so a 460 is out. A is likely the most expensive, which would rule it out. I'm inclined to go with C and hope for the best. If I do end up doing A or B at some point, I would swap in a straight-up timing set to get a little more power. The factory setup is retarded 4 degrees. I've read that this change alone makes a nice low-end difference. WWYD?
Earning every penny of that moderator paycheck.
DBAP
Re: Worn out engine - WWYD?
[Re: Ramrod39]
#2805197
08/04/20 09:05 PM
08/04/20 09:05 PM
Posts: 1,831 Sault Ste. Marie, Ontario, Can...
moparmike1
Just a suggestion but another option is to keep an eye out for a similar truck, but rusted, with the same 400 but better oil pressure than yours.
Another idea, as I'm typing, would a high volume oil pump solve your problem?
Mike.
[Re: moparmike1]
#2805209
08/04/20 09:18 PM
08/04/20 09:18 PM
Posts: 1,800 South Lyon MI
sleddinfool
South Lyon MI
400M? I didn't realize they put them in that late. I thought 78-79 was it. It does look nice.. I sure if it was an old mopar money wouldn't matter, lol. Kevin
71 gtx.....
[Re: NITROUSN]
#2805216
08/04/20 09:27 PM
08/04/20 09:27 PM
not_a_charger
D] Roll a set of bearings in it along with a new oil pump and drive it. Thought about that, but the engine has 189k on it. I'm concerned I'd be throwing good money after bad if I did that.
DBAP
[Re: not_a_charger]
#2805218
08/04/20 09:32 PM
08/04/20 09:32 PM
Posts: 1,638 PA
70Duster
PA
First, verify the gauge and sending unit are telling you the truth about the oil pressure. Then option C but run a thicker viscosity oil to see if pressure improves.
[Re: not_a_charger]
#2805219
08/04/20 09:37 PM
08/04/20 09:37 PM
Posts: 18,409 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
D] Roll a set of bearings in it along with a new oil pump and drive it. Thought about that, but the engine has 189k on it. I'm concerned I'd be throwing good money after bad if I did that. While that is always a gamble, in my opinion it would be a good gamble. Rock auto rods, mains, oil pump and pan gasket less than 200.00 with good parts. Cheaper less. If it bothers you to do so go with C and heavier oil which might help some.
[Re: Ramrod39]
#2805223
08/04/20 09:44 PM
08/04/20 09:44 PM
Posts: 2,331 Addison Twp, Mi.
RobG
Addison Twp, Mi.
It is a nice truck. Pull a crown vic motor out of a police car and swap it in.
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
[Re: RobG]
#2805227
08/04/20 09:47 PM
08/04/20 09:47 PM
not_a_charger
I love the truck. It would be perfect with a 5 speed (creeper low, OD high). It's currently a 4 speed with a creeper 1st gear, and with the 4:10s, it's a little steep on the freeway.
DBAP
[Re: not_a_charger]
#2805229
08/04/20 09:49 PM
08/04/20 09:49 PM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
D] Roll a set of bearings in it along with a new oil pump and drive it. Thought about that, but the engine has 189k on it. I'm concerned I'd be throwing good money after bad if I did that. I would do what I would have done in 1980 with the exception of it being PAW that the parts came from. I assume Summit has them the same way. Get the Ring/Bearing/Oil/Pump/ Gasket Rebuild Kit/ Ball Hone that Sucker and add in a new Summit Cam & Lifters "Drive the Wheels Off It" Maybe send the heads out just so I never had to mess with it again
[Re: 340SIX]
#2805234
08/04/20 10:03 PM
08/04/20 10:03 PM
Posts: 4,942 WI
Dcuda69
WI
D] Roll a set of bearings in it along with a new oil pump and drive it. Thought about that, but the engine has 189k on it. I'm concerned I'd be throwing good money after bad if I did that. I would do what I would have done in 1980 with the exception of it being PAW that the parts came from. I assume Summit has them the same way. Get the Ring/Bearing/Oil/Pump/ Gasket Rebuild Kit/ Ball Hone that Sucker and add in a new Summit Cam & Lifters "Drive the Wheels Off It" Maybe send the heads out just so I never had to mess with it again This^! Or just yank it out, throw a crank kit,oil pump and gaskets at it and jamb it back in. Did LOTS of Ford crank kits back in the day. Pull them, put it on a stand, flip it over, pull t-cover and oil pan. Yo-yo crank,t-chain and oil pump. Back together and back in the same day. All of them ate the mains causing low oil pressure. Few hundred bucks and you're good to go!
[Re: 340SIX]
#2805237
08/04/20 10:12 PM
08/04/20 10:12 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
I'd start with verifying the gauge isn't lying about the oil pressure being low. Use a real mechanical gauge. If it really is low, I'd probably try thicker oil and see what that did for it. The next step would be a compression test, and maybe a leak down test. I guess I'd really want to know what condition the motor is in. If the compression and leak down tell you the motor is pretty sound, I'd roll in the rod & main bearings, new oil pump, and a pan gasket, and maybe that timing chain and gears.
If it fails muster on the real oil pressure test and fails on the compression test, save your money for a reman motor, and then drive this one until it retires itself. I've seen low oil pressure Ford motors run a long time without issues. Gene
