Detonation effects question
#2804439
08/02/20 06:48 PM
08/02/20 06:48 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Can detonation shock scale from your cylinder walls? My new radiator is already clogged with scale from my block and it seems to have happened ever since I heard some detonation pulling a steep hill. It was a 90 degree day and that may have contributed to the detonation. The block has been in the car for about 6 years now so this isn't a new build so the scale in the radiator was somewhat of a mystery to me. I am going to flush the block and install an inline filter in the upper hose for a while and see what it catches. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Detonation effects question
[Re: fourgearsavoy]
#2804460
08/02/20 07:35 PM
08/02/20 07:35 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Can detonation shock scale from your cylinder walls? My new radiator is already clogged with scale from my block and it seems to have happened ever since I heard some detonation pulling a steep hill. It was a 90 degree day and that may have contributed to the detonation. The block has been in the car for about 6 years now so this isn't a new build so the scale in the radiator was somewhat of a mystery to me. I am going to flush the block and install an inline filter in the upper hose for a while and see what it catches. Gus Put an Anode in the block to help stop scale
[Re: fourgearsavoy]
#2804476
08/02/20 08:57 PM
08/02/20 08:57 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Absolutely can happen. Just like whacking the block with a hammer.
[Re: rickraw]
#2804477
08/02/20 08:57 PM
08/02/20 08:57 PM
fourgearsavoy
Rittman Ohio
Get some evaporust. Inside of block and rad will look like new.. I used it. It works. I have seen some videos of Thermocure flush made by Evaporust and from what I have seen it works pretty well. I might just get a gallon of Evaporust and flush it through a few times. Mike I have thought about the anode idea after I get it flushed out to keep it clean. Still don't understand how this happened all of the sudden this year
[Re: fourgearsavoy]
#2804526
08/03/20 12:22 AM
08/03/20 12:22 AM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
I run a Gano filter screen with a little magnet in my upper hose, has kept my radiator free from plugging up.
[Re: moparx]
#2804641
08/03/20 12:02 PM
08/03/20 12:02 PM
CSK
Pattison Texas
I run a Gano filter screen with a little magnet in my upper hose, has kept my radiator free from plugging up. do you happen to have a picture of this ? LINK HEre
[Re: Mr.Yuck]
#2804983
08/04/20 12:05 PM
08/04/20 12:05 PM
RapidRobert
are our upper hoses 1&3/4?
[Re: RapidRobert]
#2805156
08/04/20 07:02 PM
08/04/20 07:02 PM
fourgearsavoy
Rittman Ohio
Yeah they stock those at Summit so I'm gonna get one and a gallon of Evaporust and do some flushing then go from there. Maybe just get a new block next time around Gus
[Re: fourgearsavoy]
#2805340
08/05/20 10:22 AM
08/05/20 10:22 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Yeah they stock those at Summit so I'm gonna get one and a gallon of Evaporust and do some flushing then go from there. Maybe just get a new block next time around Gus FWIW I had a 440-6 that had about 11.25:1. I ran a Snow Performance meth/H2O kit. Ran great, could run 93 and run as much advance as I liked.
[Re: fourgearsavoy]
#2805393
08/05/20 12:51 PM
08/05/20 12:51 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
Yeah they stock those at Summit so I'm gonna get one and a gallon of Evaporust and do some flushing then go from there. Maybe just get a new block next time around Gus Who and where can you get a new block from now
[Re: Cab_Burge]
#2805881
08/06/20 06:22 PM
08/06/20 06:22 PM
fourgearsavoy
Rittman Ohio
Yeah they stock those at Summit so I'm gonna get one and a gallon of Evaporust and do some flushing then go from there. Maybe just get a new block next time around Gus Who and where can you get a new block from now Well maybe next year I really like the way this one runs, it pulls like a freight train and revs clean and crisp so I don't want to change it unless I really have to. Gus
