Re: New best for my small block Duster
[Re: J_BODY]
#2803751
08/01/20 02:40 PM
08/01/20 02:40 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
Where were you running it at? Our local track hasn't seen 2300 DA yet this year
[Re: dvw]
#2804480
08/02/20 09:10 PM
08/02/20 09:10 PM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
Thats humpin. What does it weigh? Doug It’s right around 2970 race ready with driver. Something got hurt Saturday night..... err I mean Sunday morning as round 2 completed at 3am. I thought maybe flex plate bolts, but refired and didn’t like the oil psi.... of course it was really early, I knew I was done even though I did win the round, and it had already been a long day. Head hit the pillow at 5am, got up and was on the road by 9am for the 6hr tow home. Unloaded all the stuff in 112 degree heat, and I’m pretty much fried.... I saw the winners circle picts and the sun was coming up! .... how cool is that!
[Re: J_BODY]
#2804599
08/03/20 10:18 AM
08/03/20 10:18 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I can't relate to the 1/4 times. What were the 1/8 mile numbers?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#2804600
08/03/20 10:25 AM
08/03/20 10:25 AM
Posts: 1,840 South Bend
John Brown
South Bend
I can't relate to the 1/4 times. What were the 1/8 mile numbers? A quick approximation is .66 (or 2/3) times the quarter mile time. Going the other way, 1.5 times the eighth mile et is a close approximation for a quarter mile. Neither one is exact, but it's close enough for horseshoes or hand grenades.
[Re: D-50]
#2804611
08/03/20 10:55 AM
08/03/20 10:55 AM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
I can't relate to the 1/4 times. What were the 1/8 mile numbers? Since Jay is either sleeping or working Ill tell ya. 5.833 116.48 Those numbers show his car is fairly efficient. Most likely everyone here could be better at having efficient combos but as far as it goes Jays deal is pretty decent. Can work on those short times a tad and improve that. Hopefully he will get the chance.
[Re: D-50]
#2804615
08/03/20 11:03 AM
08/03/20 11:03 AM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
My guess is he was running low 5.8xx in the1/8
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
