Re: Pinion yoke?
[Re: AndyF]
#2803133
07/30/20 11:07 PM
07/30/20 11:07 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
^^^^^This. 1350 is the way to go. The cast piece is $50 less, but considering what happens when one breaks, the CM unit is cheap insurance.
Re: Pinion yoke?
[Re: 340Cuda]
#2803677
08/01/20 11:57 AM
08/01/20 11:57 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
While I can't give any advice on the best yoke, if you want to ever have a driveshaft speed sensor running off the yoke that can be a consideration.
Some are more accommodating for a trigger wheel than others. This is a truth! I changed mine because of this
"Just a Bracket car dressed up like a streetcar"
