Page 9 of 10 1 2 7 8 9 10
Re: TH400 to RB in 69 b body info [Re: Clanton] #2802327
07/28/20 10:44 PM
07/28/20 10:44 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i have always found the lokar a pain to fill and sometimes check .
But you are looking good
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: TH400 to RB in 69 b body info [Re: tex013] #2802495
07/29/20 12:43 PM
07/29/20 12:43 PM
moparx Offline
moparx  Offline
i too, am wondering about how long it will take you to fill the transmission with that dipstick setup.
and also, sorry for your loss.
angel
Re: TH400 to RB in 69 b body info [Re: moparx] #2802517
07/29/20 01:18 PM
07/29/20 01:18 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
angel
I put 3qts in under 2 minutes from a gal jug of Max Shift 1 in the vert.
adding some progress pic
Re: TH400 to RB in 69 b body info [Re: Clanton] #2802650
07/29/20 08:23 PM
07/29/20 08:23 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
My converter bolts are short that I got with it at 1.250" long so lucky I got some at summit that are 1.5" but the bolt is about 1 thread away from hitting the front cover of the vert so I think I can use it.I did not tq it to 60ft lbs but if it hits then I think I can grind a tapper on the bolt so it will clear.Look at the vert bolt pad and the front of the vert and maybe you can see what I mean.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2802864
07/30/20 12:08 PM
07/30/20 12:08 PM
moparx Offline
moparx  Offline
could you use a 12pt head like on an ARP bolt to help with clearance ?
beer
Re: TH400 to RB in 69 b body info [Re: moparx] #2802891
07/30/20 01:27 PM
07/30/20 01:27 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
beer
That would not help me the bolt is just on the edge of too long.I can grind off .050" from the length.The bolt I got with the vert had no threads past the nut What I ended up doing is taking a feeler gauge and checking the gap after I ground .035 off all the bolt threads and ended up with .080" befor tqing the bolt[about 2 threads gap]
Re: TH400 to RB in 69 b body info [Re: Clanton] #2803281
07/31/20 12:57 PM
07/31/20 12:57 PM
moparx Offline
moparx  Offline
after re-looking at the picture, would it be possible to use a jam nut for a rod end ?
that would allow a bit more clearance. [i think ?]
beer
Re: TH400 to RB in 69 b body info [Re: moparx] #2803376
07/31/20 05:53 PM
07/31/20 05:53 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
beer
I cut/sanded off 3/4 of 1 thread[.035"] of the bolt to keep the bolt from bottoming out on the converter cover and after torquing I had about .050 to .060" gap.The nut on the bolt is fine.I used red loctite. at 55lbs.grade 8 bolt.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2803693
08/01/20 12:43 PM
08/01/20 12:43 PM
moparx Offline
moparx  Offline
beer
Re: TH400 to RB in 69 b body info [Re: moparx] #2803736
08/01/20 02:11 PM
08/01/20 02:11 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
What did you ever do about the cross member you cut out? Never saw a picture of it being reinforced. The floor sheet metal alone isn't going to cut it. I'd fix it now before you possibly damage a very expensive purchase.
Doug
Re: TH400 to RB in 69 b body info [Re: dvw] #2803752
08/01/20 02:42 PM
08/01/20 02:42 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Doug
I have not done anything with the trans member or floor yet.How/what should I do to it?to start I was going to fill in the open area with 1 piece .125" thick and as wide as the frame bolt holes
Re: TH400 to RB in 69 b body info [Re: Clanton] #2803794
08/01/20 04:23 PM
08/01/20 04:23 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I put the starter in and then started lashing the valves and I can hear the starter ring spin the starter gear so I will have to shim the starter with the shims that came with the ultra bell.The kits came with a starter nose extension but how do I know when to use that?
ps:The starter took 2 shims to get off the ring gear about .040".No more noise when I lashed the valves.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2804097
08/02/20 10:12 AM
08/02/20 10:12 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Doug
The big box hanging off the back can be cut off for a smaller[1"x4"] shelf the the trans mount will bolt to.I am not against making a whole new trans mount but I am using what I have to progress on other things.Your input is welcome.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2805054
08/04/20 03:11 PM
08/04/20 03:11 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am going to start with a 61top 63 lower tooth pulley at 3.3% od and I believe this will give me 7# of boost and about a 12/1cr[9.5 static]
Re: TH400 to RB in 69 b body info [Re: Clanton] #2805080
08/04/20 03:43 PM
08/04/20 03:43 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
WTH happened to the balancer?
Re: TH400 to RB in 69 b body info [Re: nss guy] #2805091
08/04/20 04:09 PM
08/04/20 04:09 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
LOLthe alt bolt sleeve rubbed it.The ballancer is 20 yrs old
Re: TH400 to RB in 69 b body info [Re: Clanton] #2805099
08/04/20 04:18 PM
08/04/20 04:18 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
You may want to replace it.
Re: TH400 to RB in 69 b body info [Re: nss guy] #2805105
08/04/20 04:28 PM
08/04/20 04:28 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Nah it is just a scuff and not deep.ty
Re: TH400 to RB in 69 b body info [Re: Clanton] #2810161
08/18/20 12:46 PM
08/18/20 12:46 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
This is a start on my trans member and I will have a full shelf from 1 side to the other inside from bolt hole to bolt hole.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2811043
08/20/20 11:49 AM
08/20/20 11:49 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I opened up the trans bushing mount hole 1/4" to move it back so I can get a nut on it[10mm 1.500 nut] I found a welding shop to weld everything together and I will get a price later today at Certified welding on 9603 Clinton rd Cleveland 216-961-5410 and he welded my quick release steering wheel adapter about 6yrs ago.
ps:I understand this looks like poop but we will clean things up for the finish product.
