Page 1 of 3 1 2 3
Thoughts on mild 383 #2802021
07/28/20 08:55 AM
07/28/20 08:55 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Hi everybody!
Looking for input on my matching 71 Charger Super Bee engine.
Let's start with to say that I'm somewhat on a budget. Plus I like doing the job myself so the engine will not leave my workshop until test drive.
I like being cheap but I want things to be properly done so I can rely on my engines when they are finished.
I have other projects I need to finish before this one so I'm just setting up the plan and gathering parts right now. Car is at my body guy's place and I hopefully will get it painted so I can have it finished by next summer.
Goal is to get a strong torque engine so I can keep the original converter and 3.23's. Lots of power directly from bottom makes cars fun. Power on tap is beautiful.
Talking about torque converter, I do hope it still has the correct HP 10 3/4"! It's still in the car so can't check for the moment, just came to think of it. IIRC that converter stalls around 2,500?
Well, with a stall at that level I guess it's no longer need for a real torque engine. Please, keep on reading and I'll give you the basis for my build.
Need vacuum for the power brakes but that should not be an issue with the characteristics I'm looking for.
I will port the 906's using the old templates. Cleaning up the bowls, straightening and cleaning up a little. Do a basic 3-angle valve job. Mill them if necessary to achieve correct compression ratio.
The cylinder bores will clean up with honing. Maybe not 100% perfectly clean up but good enough.
Reuse the original pistons but swap them side to side for a little more thump.
Use a windage tray and a larger pan never hurts even if this engine rarely will see rpm's over 4,500.
Have a nice pair of HP exhaust manifolds. Will build a full exhaust 2.5" H-pipe of mandrel bent aluminized tubes. Don't know what mufflers to use. Think Flowmasters are too noisy, even the 50's.
Still looking for a CH4B intake. From what I've heard and read that could be the optimal intake for a 383 like this.
Think I have an old good points distributor that I can put Petronix on. I don't trust the MP stuff anymore. Limit mechanical advance, lighter springs.
A spreadbore carb. Haven't looked for what I have. A 600 would do the job. Need to find an oval base 4bbl air cleaner to a decent price since it has the Air Grabber hood.
Will rebuild the 727 and put in a semi manual valve body. Car is column shifted.
Now the most interesting part. Cam selection.
My friend has a set original 440 adjustable rockers. I think I can make him sell them to me. If so I could go mechanical cam. If not I'll stay with stamped steelies.
Would a mechanical cam have big advantage over a hydraulic in an engine as described, or will it only make difference at higher rpm's?
What cam would you use based on the basis above?
Finally, I'm aware of 383's rod ratio and bore to stroke ratio. A high revving engine, not a torque monster. I know, but as I said before, I want a snappy, stong-off-the-bottom, daily driver but tire melting 383".
My hope is that it will run low 8's on 275 street tires in an otherwise original heavy 71 Super Bee... We'll see if that happens smile
To stroke it would make my goal easier but I'm not willing to spend that amount of money that comes with building a stroker. Especially not at this point. I am in Sweden and shipping parts from the US is a PITA these days. Been waiting for a box with parts shipped with USPS since mid May. It's stuck in Miami...
I'd be grateful for your input. Thanks in advance!
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: Thoughts on mild 383 [Re: HP2] #2802064
07/28/20 10:17 AM
07/28/20 10:17 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
CH4B is a square-bore intake; spreadbore carbs like a Thermoquad won't fit without an adapter, though you MAY be able to modify the intake.
Back in the day, we'd use a 440 AVS to pick up some CFM; now, I prefer the Eddy AVS2. I do like the T-quads though.
Cam: you can throw lift at it, but too much duration will make for lazy low-RPM response.
I'd probably keep duration under 230 @ .050 but look for around .500 lift, favoring the exhaust side for what you're doing.
I wouldn't worry about mech/hyd lifters, but I would get the Johnson or similar improved-oiling ones.
A Street Hemi pan is pretty stealthy but an additional quart capacity, and a Milodon or MP tray with the drains opened up a bit works.
I've had a 383 like the above that would indeed blaze the tires with 3.23s & stock converter, stock manifolds, cleaned up stock heads, 9.5:1 ('68 Road Runner).
Looked totally original.
Re: Thoughts on mild 383 [Re: topside] #2802079
07/28/20 10:56 AM
07/28/20 10:56 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Streetmaster is a good spreadbore intake.
Abe Lincoln
Re: Thoughts on mild 383 [Re: HP2] #2802092
07/28/20 11:29 AM
07/28/20 11:29 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
CH4B does not fit on a 383. It is made to fit on the RB engines(413, 426,440). You need to find a DP4B.
Re: Thoughts on mild 383 [Re: GomangoCuda] #2802159
07/28/20 02:46 PM
07/28/20 02:46 PM
IL
furious70 Offline
furious70  Offline
IL
Not judging your desire for a spreadbore carb, but if you do go that route, don't use the Holley Street Dominator intake, it is a low end killer.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Thoughts on mild 383 [Re: furious70] #2802325
07/28/20 10:28 PM
07/28/20 10:28 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
And a Performer intake is pretty much the same as the DP4B, but will accept a Thermoquad or other spreadbore carb. Worth considering in my opinion.
The 383 is already torque challenged down low. Don't put a single plane on it
A mechanical cam is the only cam I'd put in a 383 application if you want to mazimize street friendly power. Unless you really don't care about power and performance, and only low end torque put some tiny cam in it and go ahead and keep it hydraulic.
Re: Thoughts on mild 383 [Re: furious70] #2802345
07/28/20 11:51 PM
07/28/20 11:51 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I don’t agree with that. A street dominator is a great intake for a 383. Hood clearance is good. Need to run a 750 carb on it, just not a 1407 eddy. He also needs to make sure the compression is good, even if it means custom pistons, which last I knew it required if you wanted a sharp setup on a 383.
I want my fair share
Re: Thoughts on mild 383 [Re: topside] #2802376
07/29/20 04:54 AM
07/29/20 04:54 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Aha, took for granted CH4B (or actually DP4B as someone pointed out) would fit a spreadbore carb. I will look deeper into intakes.
I want small primaries to get high velocity speed in the range I mostly will use the engine. I also like Thermoquads but they are a hassle to adjust correctly... I have good experience of the Street Demon. 625 cfm will be more than enough but the design of the secondaries is similar to the TQ so they only give what the engine vacuum demands.
I have been looking around a little for cams. Just like you say I'm looking for high lift and low duration. Hughes has http://www.hughesengines.com/Index/...amp;level1=Q2Ftc2hhZnQ=&partid=30253 and they always state that their grinds are for Mopar .904 lifters. I have always been happy with their cams before.
71 Duster 340
Re: Thoughts on mild 383 [Re: BSB67] #2802377
07/29/20 05:00 AM
07/29/20 05:00 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
A Performer is a good candidate. I will look around.
For sure, I will go for a dual plane. With a single plane I won't even get near my goals.
Explicate why a mechanical cam would perform better in the lower rpm range. I have honestly never digged into that field. I have used mech cams in high revving street/strip engines but not in something like this.
71 Duster 340
Re: Thoughts on mild 383 [Re: SomeCarGuy] #2802378
07/29/20 05:03 AM
07/29/20 05:03 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Street Dominators are great intakes for making power. No doubt, I have been happy with them on 440's.
But with a single plane I'm giving up the rpm range I'm building the engine for. Need long runners for the lower rpm's.
71 Duster 340
Re: Thoughts on mild 383 [Re: HP2] #2802397
07/29/20 08:33 AM
07/29/20 08:33 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
4000+lb car, automatic, 3.23 rear, big tires, small engine + single plane intake and larger hydraulic cam = disappointment. piston/head combo-compression ratio/cylinder pressure are big factors in choosing the right parts for a 383, or any other engine for that matter. big ain't better when it comes to 383's.
Re: Thoughts on mild 383 [Re: HP2] #2802509
07/29/20 01:09 PM
07/29/20 01:09 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If it were me, I'd call summit and buy the 465/488 cam, try and find a used DP4B or like intake, headers, clean the heads up as best you can and use a Holley 750. As long as the engine is out you should at least go to a 2800 stall. It would really wake the thing up.
Coming soon!!!!
Re: Thoughts on mild 383 [Re: HP2] #2802523
07/29/20 01:31 PM
07/29/20 01:31 PM
SomeCarGuy Offline
SomeCarGuy  Offline
It’s not like other single planes. Low end grunt is there. They work well on a mild 383. Guys who haven’t used them just lump them in with the race stuff. I’ve had them on a 383, 400, and a 440. All street cars with 3.23 gears. Most guys haven’t used one at all and just say “it’s a single plane, can’t do that.”
Re: Thoughts on mild 383 [Re: SomeCarGuy] #2802659
07/29/20 08:44 PM
07/29/20 08:44 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
My only personal experience with the SD was on a 440 with a 10 inch 3500 converter. It worked well , but the old Torker I had on it before 60fted a tiny bit better. SD was about 1 mph faster in the 1/4 than the Torker for me. I wouldn't want to use a SD or any other single plane on a 383 with a low stall converter. The SD in this particular test had a weak low end compared to any of the dual planes : https://www.hotrod.com/articles/hrdp-0712-mopar-intake-manifold-comparo/
Re: Thoughts on mild 383 [Re: forphorty] #2802684
07/29/20 10:11 PM
07/29/20 10:11 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I was going to reference that shoot out too. Like 21 hp less with the SD than the DP4B at 3000 rpm. And average 9 hp less below 4500 rpm. My 383 car was a touch slower with the SD than a Performer on a mild ( high 12s) application. Could feel the difference cruising around town too.. Finally, even on my 500 motor dyno testing 3 intakes, the SD was noticably weaker below 4000 than the two dual planes tested. That surprised me on a 500 in motor.
Re: Thoughts on mild 383 [Re: BSB67] #2802704
07/29/20 11:49 PM
07/29/20 11:49 PM
SomeCarGuy Offline
SomeCarGuy  Offline
I knew the hr article would come up. Here is a random sampler of what they found. The differences are so little it’s unlikely to be noticed driving. The peak numbers are intriguing to look at, but who knows why those are what they are when the averages look like this. Finding a deal on a manifold would be a way to free up budget for other things than to get caught up in absolutes like “it has to be this one, can’t be this one.” Likewise hood clearance is a crucial factor. There are inches of difference between some of those manifolds.
Average 2,500-4,500: 429 lb-ft, 289 hp
Average 4,500-6,000: 419 lb-ft, 417 hp
Average 2,500-6,000: 424 lb-ft, 344 hp
Average 2,500-4,500: 414 lb-ft, 280 hp
Average 4,500-6,000: 432 lb-ft, 430 hp
Average 2,500-6,000: 421 lb-ft, 344 hp
Average 2,500-4,500: 427 lb-ft, 288 hp
Average 4,500-6,000: 415 lb-ft, 413 hp
Average 2,500-6,000: 422 lb-ft, 341 hp
Average 2,500-4,500: 421 lb-ft, 284 hp
Average 4,500-6,000: 430 lb-ft, 427 hp
Average 2,500-6,000: 424 lb-ft, 345 hp
Average 2,500-4,500: 424 lb-ft, 287 hp
Average 4,500-6,000: 428 lb-ft, 426 hp
Average 2,500-6,000: 425 lb-ft, 346 hp
Average 2,500-4,500: 423 lb-ft, 286 hp
Average 4,500-6,000: 435 lb-ft, 433 hp
Average 2,500-6,000: 427 lb-ft, 348 hp
Random heights
front 311/42, rear 451/48
front 431/44, rear 531/44
front 311/44, rear 411/48
front 331/48, rear 411/44
front 351/48, rear 411/42
front 411/42, rear 511/42
Re: Thoughts on mild 383 [Re: SomeCarGuy] #2802745
07/30/20 07:13 AM
07/30/20 07:13 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
My numbers from the article are correct, are they not? Plus that was with a large solid FT cam and pretty decent compression ratio if I remember correctly, and it was still lower by 9 hp average below 4500 rpm.
I went and looked up my dyno data for my 500 in motor. From 3000 to 4000 rpm, the SD was down on average 20 lbft torque, and 12 hp. Down 26 lbft and 15 hp @ 3500. As would be expected, it did make a touch more peak hp, and carried it longer past peak.
I've been doing this a long time as well, and I have not come across what I would call any crediable evidence that supports the age old belief that the SD is just as good down low as a dual plane.
Re: Thoughts on mild 383 [Re: HP2] #2802846
07/30/20 11:56 AM
07/30/20 11:56 AM
Me thinks your goal of running in the 8 with a 383 in your car are unobtainable tsk twocents
All kidding aside, that car is heavy and those motors are limited on how much cheap power you can make with them, been there done that(multiple times) whiney
Can you find a usable 440 crankshaft? If so I would use it by turning down the mains to 383 size and have a set of pistons made for using the stock 440 rods in your 383 , you will have to do some work, grinding the edges, on the crankshaft counterweights to clear the main webbing but increasing the stroke to 3.750 in a low deck is a really good way to help on the low end torque.
Being in Sweden has to limit your ability and choices on parts for this project so I can feel your pain and frustrations work good luck up
Re: Thoughts on mild 383 [Re: Cab_Burge] #2802857
07/30/20 12:05 PM
07/30/20 12:05 PM
IL
furious70 Offline
furious70  Offline
IL
I've done back to back comparisons, same car, same engine, same tires with OEM and SD intake. SD intake and 3.91's, barely spin tires on idle stomp. OEM intake and 3.23's, much more spin from idle stomp. That's proof positive of low end difference.
This was a basically stock magnum 383 spec motor with 268H cam and 906's with normal 3 angle VJ, headers, 750 holley, nothing fancy at all.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Thoughts on mild 383 [Re: HP2] #2802886
07/30/20 01:04 PM
07/30/20 01:04 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I think you my have missunderstood my point, but my my wording was poor as well.
In short, maximizing power (track performance), and low rpm torque (the low speed "feel" of the motor) is hard, paticularly with a 383. These things compete with one another in a 383 more so than 440s. You also made a statement about 4500 rpm, and not sure what to infer from that. A stock 383 is pretty happy at 5500.
Anyways, to have your cake and eat it too, you need to put a cam in it that moves the valves fast, but will still keep the valvetrain happy to 6000 rpm. The fast rate hydraulic cams (or lifters) usually struggle at higher rpm. A faster rate solid cam can do both. Also, loosening the valve lash will sharpen-up the low throttle response noticably on a 383. The faster you move the valves and slap the valvetrain around, the harder it is on parts. It's always a compromise.
Page 1 of 3 1 2 3
