Dipstick tube sizes #2801718
07/27/20 01:15 PM
07/27/20 01:15 PM
Sweden
MikeN Offline OP
MikeN  Offline OP
Sweden
Noticed that the dipstick tube hole in the engine block (World gen II Hemi) is 11/32" while the mopar dipstick tube has an OD of 3/8". Is there a special dipstick tube with correct size?
Re: Dipstick tube sizes [Re: MikeN] #2801880
07/27/20 08:24 PM
07/27/20 08:24 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
shruggy Dunno, what is the source for the dipstick. Some do vary especially the plated ones.
It's not uncommon for some to be a bit oversized But 1/32 sounds a bit much. Depending an the wall thickness a quick pass or two while spinning the tube across a belt sander can make them slip right in. A bit of sealer and you're done twocents
