Oil pump drive gear backlash #2801524
07/26/20 09:38 PM
07/26/20 09:38 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Hello,
I noticed upon disassembly the oil pump drive gear had more backlash than I expected.
Going together now with a new cam and drive gear and it is the same.
Moving the cam fore/aft in the block (upper timing gear loose) does not tighten it up.
I ground the step off the base of the old gear to see if dropping it down would tighten it up. Same, no difference.
Bushing in block does not seem worn, no excessive play against shaft.
Here's a video with current parts and pic of wear patterns of old parts. Not sure how I could even improve this but something to chase or is this how they all are?
Thank you.
https://www.youtube.com/watch?v=fbRHukeqEUY&feature=youtu.be
Re: Oil pump drive gear backlash [Re: INTMD8] #2801591
07/27/20 05:40 AM
07/27/20 05:40 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Make sure the intermediate shaft isn't bottoming out in the oilpump.
OTH, the oilpump is always causing a constant drag on the intermediate shaft, so the backlash is always taken up by this in a running engine.
Re: Oil pump drive gear backlash [Re: BigBlockMopar] #2801663
07/27/20 11:10 AM
07/27/20 11:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You most likely need to stop the upper movement in the dist.. that will reduce the dist turning.. I use a
collar on the dist shaft.. that will stabilize the turning and lift in the dist
wave
Re: Oil pump drive gear backlash [Re: INTMD8] #2801664
07/27/20 11:12 AM
07/27/20 11:12 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Looks like that intermediate shaft gear needs to be replaced. In a lot of cases, the tang in the distributor is typically too short to hold the intermediate shaft at the correct distance off the block bushing. This can allow the gear to lift up and down excessively while the motor is accelerated and decelerated, which can cause excessive wear to the gears. My bronze gears would barely make it to 1500 miles until I discovered the excessive play.
One easy fix is to install a collar on the bottom of the distributor shaft that rides on the upper sleeve of the intermediate shaft, just above the drive tang. You will need to adjust it's position on the distributor shaft to allow clearance for the oil to fit between the bottom of the intermediate shaft gear and the block bushing. You can even use a feeler gauge if your intake and/or valley pan are off depending if big block or small block..
Re: Oil pump drive gear backlash [Re: INTMD8] #2801680
07/27/20 11:35 AM
07/27/20 11:35 AM
central il.
second 70 Online content
second 70  Online Content
central il.
Make sure you have the right length oil shaft. There are 3 different sizes based on which oil pump you're using.
Re: Oil pump drive gear backlash [Re: second 70] #2801684
07/27/20 11:42 AM
07/27/20 11:42 AM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
There's no oil pump on the engine right now. The shaft in the video is new, photos are of the old one.
Thanks guys.
Re: Oil pump drive gear backlash [Re: second 70] #2801706
07/27/20 12:35 PM
07/27/20 12:35 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I thought I remembered a oil groove in the block bushing??
Joe
Re: Oil pump drive gear backlash [Re: jlatessa] #2801717
07/27/20 01:14 PM
07/27/20 01:14 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I actually was just looking at mine this weekend. My milodon intermediate gear was run without a stop collar for a bit and is pretty worn. I had a good OEM one that I put in and my backlash is similar to yours. It was much worse with the worn gear.
Even with the stop collar my timing seems to jump around about 2 degrees, and I wonder if that backlash has to do with it. As mentioned I would think the drag from the oil pump would keep this loaded in one direction.
Re: Oil pump drive gear backlash [Re: GTX MATT] #2801841
07/27/20 07:08 PM
07/27/20 07:08 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Hmm, interesting. You gave me the idea to check the original engine from my car.
There was less play, probably half.
Pulled that original shaft out and tried it in the current engine, same play as the new aftermarket shaft.
So, either newer cams have the gear cut differently (as it's the same with both I have) or the hole in the block for the intermediate shaft is too far away from the cam.
Could probably have an offset bushing made but now how does the shaft align with the oil pump.
Re: Oil pump drive gear backlash [Re: INTMD8] #2801868
07/27/20 08:06 PM
07/27/20 08:06 PM
Washington
hemienvy Online content
hemienvy  Online Content
Washington
I hope the folks here are able to track down and fix their problem.
But this whole thread shows why I want to use an external belt-driven oil pump.
Re: Oil pump drive gear backlash [Re: hemienvy] #2802123
07/28/20 12:50 PM
07/28/20 12:50 PM
dist tang to intergear fit can make the timing jump around. with everything (dist/intergear/pump) buttoned up, lightly move the rotor back & forth & see how much slop you have and always have the pump installed before the intergear install to insure a dead on hex alignment. A person might add some material (weld?) to the dist lower tang for a tighter fit. a sloppy tchain will also make the timing jump around.
