W5 Heads Jesel Sportsman series rocker arms??? #280170
04/07/09 04:54 AM
04/07/09 04:54 AM
Cairns Queensland Australia. T...
V
vc360 Offline OP
vc360  Offline OP
V
Anybody know if Jesel do a sportsman rocker arm set for the w5 heads. They list a couple for the w2's, was just wondering if anybody has used them on the w5 at all and knows the correct part number?
thanks
Re: W5 Heads Jesel Sportsman series rocker arms??? [Re: vc360] #280171
04/07/09 07:23 AM
04/07/09 07:23 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
W-5 is the same as W-2 kit. Part number depends on rocker ratios.
KSS-346050........1.60 IN/1.50 EX
KSS-346060........1.60 IN/1.60 EX
KSS-346560........1.65 IN/1.60 EX
KSS-347070........1.70 IN/1.70 EX
They will probably make up a set using any ratio you want, up to maybe 1.80
