I'm sure this has been asked before. Converting my Challenger from auto to four speed. Getting ready to detail/paint underside and engine bay. Wondering if anyone has pictures/measurements/etc. of where proper placement is for the Z bar bracket on the front frame rail and where the holes would be drilled for the torque strap that comes through firewall to the clutch/brake pedal setup. What else do I need to do? Hump is welded in already.
Also, I'm going to install a shaker setup. Where does the shaker cable hole go? I'm pretty sure passenger side below the voltage regulator.
Any help and pictures/diagrams would be appreciated. Thanks!
