Re: Leaky Rear Pinion
[Re: cjskotni]
#2801631
07/27/20 09:36 AM
07/27/20 09:36 AM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
Have to pull the Yoke and get a Speedy Sleave. Also get a new seal. Problem solved.
Abe Lincoln
[Re: dart4forte]
#2801634
07/27/20 09:41 AM
07/27/20 09:41 AM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Have to pull the Yoke and get a Speedy Sleave. Also get a new seal. Problem solved. Anybody have the part number for the one to fit my application? I am trying not to have to pull it apart and then order parts. This car does have a pretty stout motor so I was wondering if this would be a good time to just swap the yoke with a stronger one. I am not sure if these tend to be the weak link in the drivetrain..
[Re: cjskotni]
#2801655
07/27/20 10:43 AM
07/27/20 10:43 AM
Posts: 1,637 Florida
GMP440
It's possible that it may not be the yoke if the yoke is not grooved or scratched., but the way the pinion seal was sealed on installation. When putting in the pinion seal it's good to smear some rtv in the area that the pinion seal butts up against. This prevents a lot of leaks. I would ask the shop if they did this.
[Re: Pacnorthcuda]
#2801687
07/27/20 11:52 AM
07/27/20 11:52 AM
cjskotni
North Carolina
It’s a 489 and nobody has mentioned the god-forsaken crush sleeve. If the sleeve was eliminated with a solid spacer during the last rebuild great, but if it still uses one the correct fix involves removing the carrier, the diff, and the pinion for a new sleeve or spacer.
Sorry, but that’s the nature of the beast. You can attempt to just replace the seal and return the pinion nut to its exact location, but if you don’t get it right you are on borrowed time. Good point. I ordered the crush sleeve eliminator kit along with a new seal and speedi-sleeve. Anything else I should need?
[Re: Pacnorthcuda]
#2801689
07/27/20 11:55 AM
07/27/20 11:55 AM
Posts: 4,722 Moved to N.E. Tennessee
GomangoCuda
Sorry, but that’s the nature of the beast. You can attempt to just replace the seal and return the pinion nut to its exact location, but if you don’t get it right you are on borrowed time. I was in the process of writing almost the exact same thing but stopped to do something more pressing. The yoke has been off twice for seal replacement and who knows wether the crush sleave was even replaced when the r&p was changed. I agree 150% that the whole thing should come apart. Sorry
[Re: GomangoCuda]
#2801691
07/27/20 12:00 PM
07/27/20 12:00 PM
cjskotni
North Carolina
Sorry, but that’s the nature of the beast. You can attempt to just replace the seal and return the pinion nut to its exact location, but if you don’t get it right you are on borrowed time. I was in the process of writing almost the exact same thing but stopped to do something more pressing. The yoke has been off twice for seal replacement and who knows wether the crush sleave was even replaced when the r&p was changed. I agree 150% that the whole thing should come apart. Sorry What else will I need to buy aside from the aforementioned parts?
[Re: cjskotni]
#2801743
07/27/20 02:18 PM
07/27/20 02:18 PM
GomangoCuda
If I really have to pull the entire carrier, this is getting a bit beyond my expertise. Is there a good book on the 8.75 rear I can reference? Factory Service Manual is what you need.
[Re: GomangoCuda]
#2801747
07/27/20 02:21 PM
07/27/20 02:21 PM
GomangoCuda
Where the rebuild and the two subsequent pinion seals all done by the same "mechanic"? Don't go back to him.
[Re: GomangoCuda]
#2801799
07/27/20 05:07 PM
07/27/20 05:07 PM
cjskotni
North Carolina
Where the rebuild and the two subsequent pinion seals all done by the same "mechanic"? Don't go back to him. I got the factory manual in PDF and started looking it over. The diff was rebuilt around 15 years ago by a shop that specialized in drivetrains. The seal started leaking years later at which time I had another shop (closer to home) re-do the seal twice. I'd like to learn how to do this but I am worried this will spiral out of control if I have to tear down the whole rear nd, pull axles, etc.
[Re: moparx]
#2801889
07/27/20 08:34 PM
07/27/20 08:34 PM
Posts: 15,366 Omaha Ne
TJP
Omaha Ne
when installing the yoke on the pinion, apply a little rtv on the splines to prevent any wicking that may appear to be a seal leak. also, if the seal has a garter spring facing the pinion, pack that area with wheel bearing grease to prevent the spring from popping off the seal when it's being installed. Listen To what the man is telling you I've even been known to add a bit of sealer behind the washer
[Re: NITROUSN]
#2801913
07/27/20 09:54 PM
07/27/20 09:54 PM
Posts: 259 n.c.
geo.
n.c.
Has the vent been checked to make sure it is not plugged solid? Good idea! I've got a Ram cab&chassis that took a couple of years to start leaking, discovered the vent nipple wasn't drilled!
[Re: cjskotni]
#2801936
07/27/20 11:11 PM
07/27/20 11:11 PM
GomangoCuda
How bad does it leak? 6" spot in 1 day? 1 week? 1 month? 1 year? How often do you need to add fluid? Maybe a drip pan is a reasonable option.
[Re: cjskotni]
#2801960
07/28/20 12:25 AM
07/28/20 12:25 AM
dart4forte
Mesa, Arizona
So we thinking a speedi-sleeve and a new seal will fix it? At this point, I am hesitant to take this to a mechanic since I have had this done twice already...
I can get the right tools to get the pinion nut torqued down properly. I really don't want to pull the whole carrier out if I don't have to. I don't have any other issues/noises/vibrations - just the leak.
You’ll have to measure the circumference of the Yoke. Parts store should be able to fix you up. Also, dab a small film of grease on the rubber seal so it’s not dry when you start down the road. A dry seat will most certainly be the cause of future leaks. Of course as was mentioned pulling the pig and getting it on the bench is the way to go.
Abe Lincoln
