W7 Spark Plug #2801059
07/25/20 04:06 PM
07/25/20 04:06 PM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
what plug should i run in my W7 14.9 compression 394 CI motor on 114 race gas? Thanks
Re: W7 Spark Plug [Re: Plymouth340] #2801346
07/26/20 01:44 PM
07/26/20 01:44 PM
Does it us ethe 3/4 long body?
If so I would try a #8 NGK ( I don't know the current part #, sorry) or Autolite 3932 or a 3910, the 3932 has a retracked gap and the 3910 has the projected gap scope
Re: W7 Spark Plug [Re: Cab_Burge] #2801355
07/26/20 02:08 PM
07/26/20 02:08 PM
CEDAR RAPIDS
CEDAR RAPIDS
yes .750 body....maybe NGK R5672A8 ?
Re: W7 Spark Plug [Re: Plymouth340] #2801382
07/26/20 03:10 PM
07/26/20 03:10 PM
Like I said when NGK changed their part numbers I didn't keep up realcrazy
If that plug has the #8 on the base as the last number it is a #8 up
If it has a projected gap and clears your pistons try it up twocents If it has the retracted gap it will clear so try it also twocents
