58 Plymouth, 12 volt? #2801234
07/26/20 09:06 AM
07/26/20 09:06 AM
S.E. Missouri
AeroMonte Offline OP
S.E. Missouri
I just bought my first 58 Plymouth Belvedere. I'm assuming it is 12 volt negative ground but just want to be sure before I put a battery in the old girl.
Re: 58 Plymouth, 12 volt? [Re: AeroMonte] #2801249
07/26/20 09:52 AM
07/26/20 09:52 AM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
Should be 12V. Plymouth went from 6V/ positive ground to 12V/ negative ground in 1956.
Re: 58 Plymouth, 12 volt? [Re: AeroMonte] #2801250
07/26/20 09:53 AM
07/26/20 09:53 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
It ought to be, 55 was the last year for 6v.
FSM and parts manual available here
http://www.mymopar.com/index.php?pid=31
Re: 58 Plymouth, 12 volt? [Re: Sniper] #2801255
07/26/20 10:11 AM
07/26/20 10:11 AM
S.E. Missouri
S.E. Missouri
Thanks for the help
Re: 58 Plymouth, 12 volt? [Re: AeroMonte] #2801257
07/26/20 10:20 AM
07/26/20 10:20 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
55 was last year for 6 volt.56 was 12 and neg ground.We have had both One 47 I had we ran a 9 volt battery.Rocky
Chrysler Firepower
Re: 58 Plymouth, 12 volt? [Re: therocks] #2801263
07/26/20 10:39 AM
07/26/20 10:39 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Our '57s were 12V Neg ground, like a proper automobile dammit laugh2
Re: 58 Plymouth, 12 volt? [Re: topside] #2801328
07/26/20 01:13 PM
07/26/20 01:13 PM
Cab_Burge Online work
Cab_Burge  Online Work
Most European 12 volt cars back then maintained the negative side as the hot side, not negative ground like American cars switch to when they converted to 12 volt. GM converted Buick, Cadillac and Oldsmobiles (SP?)to 12V in 1953,not sure about Pontiac and they converted Cheverolet to 12V in 1955.
Mopar and Ford switch all their cars to 12V in 1956.
All the current in battery flows from the negative side back to the positive side, they only flow from positive to negative internally shruggy Hence the importance of proper and good grounding up
Both ways work up shruggy
Re: 58 Plymouth, 12 volt? [Re: Cab_Burge] #2801335
07/26/20 01:22 PM
07/26/20 01:22 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
positive ground encourages galvanic corrosion and shorter plug life.
While they both work, negative ground works better.
