Changing Oil Pan Gasket #2800686
07/24/20 04:56 PM
07/24/20 04:56 PM
Ont, Canada
gygeneral Offline OP
Ont, Canada
I have not much work on engines, I usually have other people do that, but I have a nasty oil leak and I am thinking of ghanging the oil pan gasket myself.
Is it possible without lifting/moving the engine. I realize the center link will have to come out but I'm not sure if that pan will drop and clear the kframe.
Its a 440 , stock oil pan in a 71 Roadrunner.
Re: Changing Oil Pan Gasket [Re: gygeneral] #2800688
07/24/20 05:01 PM
07/24/20 05:01 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
real pain in the butt if you're using a windage tray. an extra pair of hands doesn't hurt either. i'd probably never do it again.
Re: Changing Oil Pan Gasket [Re: lewtot184] #2800720
07/24/20 06:32 PM
07/24/20 06:32 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
FIRST make sure it’s leaking there ....
Then ADD a windage tray if it doesn’t have one ....
AND ... you can make that ADDING A TRAY lots easier
Re: Changing Oil Pan Gasket [Re: dOrk !] #2800731
07/24/20 07:19 PM
07/24/20 07:19 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
you ever done this before WITH a windage tray?
Re: Changing Oil Pan Gasket [Re: lewtot184] #2800809
07/24/20 10:51 PM
07/24/20 10:51 PM
Indiana
68_661charger Offline
Indiana
Ive pulled the pan on a 383 with a windage tray but on a 68 Charger. Once center link was out of the way it wasnt that bad. I think I only removed 1 point of the center link and just pushed it out of the way instead of removing but its been a long time.
Re: Changing Oil Pan Gasket [Re: lewtot184] #2800814
07/24/20 10:58 PM
07/24/20 10:58 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Yes .... several times.... but it’s TONZ EASIER if you glue(silicone) the gasket on both sides of the tray FIRST ..... AND let it set up for a couple of hours OR overnight....
Re: Changing Oil Pan Gasket [Re: dOrk !] #2800817
07/24/20 11:03 PM
07/24/20 11:03 PM
Ont, Canada
Ont, Canada
I was thinking of using that molded gasket that incorporates the windage tray. It would easier than trying to piece a tray and two gaskets.
So I gather there is room to remove the pan, I wasn't sure if the oil pick up would be in the way.
Still not convinced I should try this lol
Re: Changing Oil Pan Gasket [Re: gygeneral] #2800818
07/24/20 11:09 PM
07/24/20 11:09 PM
AndyF Online content
AndyF  Online Content
Get the car up in the air and just check to see if you can get a socket on every bolt. If you can get a socket on each bolt then you should be able to pull the pan without too much of struggle. I use studs on the ends to make things easier. The studs line up the gaskets and windage tray so it all goes together easier.
Re: Changing Oil Pan Gasket [Re: gygeneral] #2800819
07/24/20 11:10 PM
07/24/20 11:10 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Gaskets and the tray already together ??
A tray IS a worthy add on performance item up
Re: Changing Oil Pan Gasket [Re: dOrk !] #2800870
07/25/20 07:49 AM
07/25/20 07:49 AM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
Hi,
Yes, this is possible. I've done it on a 1972 Road Runner with a 400.
As mentioned, the center link needs to be disconnected at one point and moved out of the way, doesn't need to be removed.
Here's a link to the one-piece windage tray I used:
https://www.jegs.com/i/JEGS/555/502000/10002/-1
Was it easy? Not completely but I've seen worse.
Good luck,
Mike.
Re: Changing Oil Pan Gasket [Re: moparmike1] #2800883
07/25/20 08:58 AM
07/25/20 08:58 AM
Ont, Canada
Ont, Canada
Ok thanks evryone, I think i'm going to try it, just ordered that one piece tray.
Re: Changing Oil Pan Gasket [Re: gygeneral] #2800901
07/25/20 09:59 AM
07/25/20 09:59 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Another tip is that on some cars, the front of the pan gets caught a crank counterweight when you're sliding it backwards.
Just rotating the crank maybe 30 degrees clears that.
You do want to verify it's not a rear main seal leak - all too common - which a pan gasket won't fix.
Re: Changing Oil Pan Gasket [Re: moparmike1] #2800941
07/25/20 11:29 AM
07/25/20 11:29 AM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Originally Posted by moparmike1
Hi,
Good luck,
Mike.
That’s a PLASTIC tray ? eek
Re: Changing Oil Pan Gasket [Re: gygeneral] #2801031
07/25/20 03:01 PM
07/25/20 03:01 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Jegs says for use with a flat pan rail like a fabricated pan would have. Here is a picture of the gasket/tray and a picture of a typical stock type stamped steel pan rail. Good luck with that. Maybe you could fill the stiffening beads in the pan rails with epoxy so that the ribs in the gasket would have something to seal against.
Re: Changing Oil Pan Gasket [Re: gygeneral] #2801060
07/25/20 04:10 PM
07/25/20 04:10 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I believe those are designed to be reuseable, if so then tie each hole in the gasket to the pan using thread and install it.
I will make your life so much easier.
Re: Changing Oil Pan Gasket [Re: GomangoCuda] #2801140
07/25/20 08:18 PM
07/25/20 08:18 PM
Ont, Canada
Ont, Canada
the pic of that gasket is the up side, the engine block sealing surface, I wonder what it looks like on the bottom side, where it would seal against the cover. I see your point about the stiffening beads, Summit site does not say the same as the Jegs site
Re: Changing Oil Pan Gasket [Re: gygeneral] #2801141
07/25/20 08:25 PM
07/25/20 08:25 PM
Ont, Canada
Ont, Canada
Ok found my answer on the Mr Gasket website, it has pics of both sides and they are the same. See the info under Tech Resources at the bottom
https://www.holley.com/products/accessories/oil_pans/oil_pan_accessories/parts/61100G
