Re: 400 inch sb with trick-flow 190 heads [Re: pittsburghracer] #2800534
07/24/20 09:45 AM
07/24/20 09:45 AM
bronx n.y
O
one bad fish Online content
one bad fish  Online Content
O
bronx n.y
Originally Posted by pittsburghracer
Originally Posted by one bad fish
i heard those victors r good
I’ve gone 9.40’s with my Indy 360-1 heads but I would love porting a set of the Victor heads to see what I could go with them. They require different pistons so maybe when mine are worn out. I’m still running a solid lifter cam so that would have to change too so it would make the expense worthwhile
i like my indys
Re: 400 inch sb with trick-flow 190 heads [Re: one bad fish] #2800542
07/24/20 10:15 AM
07/24/20 10:15 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
i like my indys
My buddy bought a set of 245 cnc’d 360-1 heads and then sent them to Ryan and then a local Pa head porter. He has been fighting a water leak and my son and I found a hole in number 7 exhaust. I took them to be welded and pressure tested three different times and finally gave up on them Wednesday. They are paper thin in that exhaust port and someone did some butcher work in that port. He picked up another stock 245 cnc’d head that will be going on.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 400 inch sb with trick-flow 190 heads [Re: fast68plymouth] #2800550
07/24/20 10:32 AM
07/24/20 10:32 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted by fast68plymouth
Quote
I gave $700 for the heads, then sent them to Curtis Boggs. He charged $1100 to port, do a 5 angle valve job and mill them to 55cc chambers.
What year did that happen?
Probably 15 years ago, the heads were bought used.
Re: 400 inch sb with trick-flow 190 heads [Re: justinp61] #2800552
07/24/20 10:41 AM
07/24/20 10:41 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Sooooo......I’d say it’s reasonable to assume prices might be a little higher now smoke
Re: 400 inch sb with trick-flow 190 heads [Re: fast68plymouth] #2800577
07/24/20 11:15 AM
07/24/20 11:15 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I would say yes they have gone up. I think I have $15-1600 in the porting in my Indy heads and intake from four years ago.
Maybe as more guys run the Trick Flows their advantage over ported Edelbrocks will show up on the time slip. It would be interesting to see what a good ported could do with a set to see what the potential really is.
Re: 400 inch sb with trick-flow 190 heads [Re: justinp61] #2800608
07/24/20 12:30 PM
07/24/20 12:30 PM
PA.
"Little"John
"Little"John
PA.
We had this discussion over on Abodiesony. You can’t buy a head that flows 300cfm@.700 lift and run a .501 purple shaft hydraulic cam and see miracles.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 400 inch sb with trick-flow 190 heads [Re: pittsburghracer] #2800611
07/24/20 12:40 PM
07/24/20 12:40 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I never thought that was the target market.
Re: 400 inch sb with trick-flow 190 heads [Re: justinp61] #2800617
07/24/20 12:46 PM
07/24/20 12:46 PM
PA.
"Little"John
"Little"John
PA.
It’s a head aimed at the street, street strip guys. They told me that several times. Rumor is the new intake is very close after some quality control issues and I look for good news from TrickFlow in the near future.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 400 inch sb with trick-flow 190 heads [Re: pittsburghracer] #2800626
07/24/20 01:11 PM
07/24/20 01:11 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Has anyone noticed the odd shape of the TF exhaust ports? They appear they will not match exhaust gasket ports... especially the outer two ports.
Re: 400 inch sb with trick-flow 190 heads [Re: Mopar Mitch] #2801036
07/25/20 03:14 PM
07/25/20 03:14 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Yes I noticed it too on mine
But I was told they will be fine. So far I haven't had any exhaust leaks with my hooker headers.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: 400 inch sb with trick-flow 190 heads [Re: mopar65] #2801577
07/27/20 01:24 AM
07/27/20 01:24 AM
Washington
skrews Offline
skrews  Offline
Washington
Looks like they filled in the floor, thus giving them that odd looking shape. Would like to see a gasket placed on one.
Re: 400 inch sb with trick-flow 190 heads [Re: skrews] #2801669
07/27/20 11:17 AM
07/27/20 11:17 AM
So. Burlington, Vt.
So. Burlington, Vt.
As long as there is a decent amount of material to back up the gasket where the header will be pushing on it, I don’t see any issues.
If the head was made without taking that into account, it would be a pretty big fail.
Since there are several reports of people running them, and no talk of incurable header leaks...... I’m thinking it’s “no problemo”.
Re: 400 inch sb with trick-flow 190 heads [Re: fast68plymouth] #2801767
07/27/20 02:59 PM
07/27/20 02:59 PM
Mopar Mitch Offline
Mopar Mitch  Offline
Yeah... I'd like to see a picture of a gasket... header gasket... placed over the ports.... Fel-Pro #1413 is most common.
