Re: 67 9-1/4 rear? [Re: cudaman1969] #2799283
07/21/20 09:47 AM
07/21/20 09:47 AM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
Width of the 67 C-body dana I removed was 61 5/8 drum to drum and is regarded as such.
I do know it was a direct fit into an E-body.
E-body dana width drum to drum is 61 3/4.
Spring perch distance center to center of both the E-body 9 3/4 dana and the C-body 9 1/4 dana is 46 " for both.
As I stated, it bolted right into an E-body
Re: 67 9-1/4 rear? [Re: mccannix] #2799303
07/21/20 10:32 AM
07/21/20 10:32 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I had a 69 Fury III 4-door 383 2-bbl as my first car and it had a Chrysler 9-1/4 rear, it was my second car. I believe that was the first use of the non-Dana 9-1/4 in a Chrysler product. Of course it blew up and I parted out the car...
JB Rhinehart, Realist
A-Body's RULE!
Re: 67 9-1/4 rear? [Re: mccannix] #2799343
07/21/20 12:17 PM
07/21/20 12:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
But did you check the pinion angle?
The gist of this thread is that the OP cited a FSM that is not body specific. The quote from the FSM is relative to C-bodies only.
Re: 67 9-1/4 rear? [Re: John_Kunkel] #2799412
07/21/20 02:36 PM
07/21/20 02:36 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Yep , the fsm should have said the cars had rears, engines, trans and wiring and left it at that, why do we need a service manual?
EXCLUSIVE, Webster’s definition; not shared - available to only one person or group.
Hemi engine 4 speed has 9-3/4 ONLY, so it’s wrong wording or typo or whatever you want to call it, not generic or body specific.
a-body b-body c-body has nothing to do with my point
Re: 67 9-1/4 rear? [Re: John_Kunkel] #2799503
07/21/20 06:43 PM
07/21/20 06:43 PM
Ontario, Canada
Ontario, Canada
Quote
Yep.. I know what the the gist of the thread is...I was merely answering cudaman1969's last question stating he'd
..."like to know the width of the c-body 35 drum to drum"......which I provided.
The rest is just an interesting observation regarding what the 9 1/4 C dana will bolt right into should someone ever stumble onto one.
Re: 67 9-1/4 rear? [Re: mccannix] #2799603
07/21/20 11:57 PM
07/21/20 11:57 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I have an NOS C-body Dana 53 housing.
Re: 67 9-1/4 rear? [Re: DoctorDiff] #2799655
07/22/20 08:52 AM
07/22/20 08:52 AM
fredericksburg,va
fredericksburg,va
Cool, what else did they use the 35 in?
Re: 67 9-1/4 rear? [Re: cudaman1969] #2799946
07/22/20 06:53 PM
07/22/20 06:53 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I've seen Dana 53 rears in Jeep pickups and 50's Lincolns.
Re: 67 9-1/4 rear? [Re: DoctorDiff] #2799976
07/22/20 09:06 PM
07/22/20 09:06 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have a Dana out of an International Scout with 5-bolt axles, is is a 60 or a 53? shruggy
A-Body's RULE!
Re: 67 9-1/4 rear? [Re: Rhinodart] #2799987
07/22/20 09:24 PM
07/22/20 09:24 PM
N
NITROUSN Offline
NITROUSN  Offline
N
DANA 44
Re: 67 9-1/4 rear? [Re: NITROUSN] #2803710
08/01/20 01:16 PM
08/01/20 01:16 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Scouts used a few different Dana axles and all were 5 lug.
Could be a 27, 30 or 44. Year and engine can help determine.
Angry white pureblood male
Re: 67 9-1/4 rear? [Re: ruderunner] #2804320
08/02/20 04:35 PM
08/02/20 04:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I have a Dana 44 from a Scout, has the same 30-spline on the axles as an 8 3/4".
