Page 1 of 3 1 2 3
To Spray Gray or not, that is the question? #27998
06/02/06 01:54 AM
06/02/06 01:54 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
There is a few post going on about what color front suspension parts should be and how to obtain that color. The truth is first you have to see what color was the part originality, black, natural iron or cosmoline. Then it is up to the person doing the work to determine what are they going to do with the car, drive it, trailer queen or both. If it is a trailer queen then cosmoline and natural, uncoated iron will work just fine but I personality I plan on driving this thing and I don't want rust poping up or cosmoline geathering bugs and dirt. I want my car to look as good as it goes. So this is how I duplicated the look of iron front end parts and with the many coats of paint they should last a very long time.
Here is my knuckles, caliber brackets and center link.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: To Spray Gray or not, that is the question? [Re: Troy] #27999
06/02/06 02:02 AM
06/02/06 02:02 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
What I did was sand blast the part (A good cleaning with a degresser and a wire brush will also work) and I shot the whole part with Krylon satin black. After that I fogged the part with Eastwood Spry Gray making sure I just barley misting the parts giving the part a gray tint. Then comes the Krylon Satin Clear. It takes a little practice but I'm very happy with the way it comes out. Total cost....$16.50
Re: To Spray Gray or not, that is the question? [Re: Troy] #28000
06/02/06 02:03 AM
06/02/06 02:03 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
another....
Re: To Spray Gray or not, that is the question? [Re: Troy] #28001
06/02/06 02:04 AM
06/02/06 02:04 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
....another.....
Re: To Spray Gray or not, that is the question? [Re: Troy] #28002
06/02/06 02:11 AM
06/02/06 02:11 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
On parts with cosmoline I clean the part, shoot it with Eastwood Spay Gray and then I use the Eastwood Anti Rust Inhibitor or everybody else calls it cosmoline. After letting it dry for FOUR DAYS (I'm not kidding) It is still tacky to the touch so I shoot it with Krylon Satin Clear. This makes it so you can touch the parts and wipe it clean if it gets dirty but don't rub it to hard because it will come off. I'm still trying to come up with something that will harden 100% but till then this will do.
Hope this helps.
Re: To Spray Gray or not, that is the question? [Re: Troy] #28003
06/02/06 02:12 AM
06/02/06 02:12 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
another...
Re: To Spray Gray or not, that is the question? [Re: Troy] #28004
06/02/06 02:14 AM
06/02/06 02:14 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
I found this and I don't know if I have ever saw this before, date code on the spindle. I thought I would toss this in.
Re: To Spray Gray or not, that is the question? [Re: Troy] #28005
06/02/06 03:55 AM
06/02/06 03:55 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Troy
Heres something you can try, to simulate cosmoline I tried the Eastwood stuff, like you found it doesn't dry, so I tried other products & found Krylon battery corrosion spray, it lays down semi transparent, with a yellow/brownish appearance, by recoating you can darken the part as desired, it drys completely, its acid proof I did it over ten years ago & it held up well for the first six or seven years but in the last few I used a more aggressive cleaner on the frontend & it lightened the color some, if I really cared I could recoat it, but I really just drive the car anymore & while I keep it up pretty good I don't sweat those type of details much..
Re: To Spray Gray or not, that is the question? [Re: 1_WILD_RT] #28006
06/02/06 10:37 AM
06/02/06 10:37 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
That is a good one, I'll give it a try. I tried the Eastwood Carburetor paint and it just did not do it.
Another paint that I picked up was a Krylon paint called Hammered (or something like that) It is a gray paint that dries with a texture and it dries both light and dark gray color to it.
Re: To Spray Gray or not, that is the question? [Re: Troy] #28007
06/02/06 03:21 PM
06/02/06 03:21 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Re: To Spray Gray or not, that is the question? [Re: A12] #28008
06/05/06 10:02 PM
06/05/06 10:02 PM
across the river from Portland...
472 R/T SE Offline
472 R/T SE  Offline
For cosmoline, we used the gold can from the 3 can package for gold cad. from Eastwood. And then a can of Chebby dark gold.
My buddy in Red Deer uses varnish. Then if it get's chipped or time to clean, he brushes some more on.
[color:"purple"]HELP SUPPORT THE REGISTRIES.All cars matter.
1970 Charger Registry
I like to sleep For I'm walking in my dreams.
Live life like every DAY is your last!
Chrysler R/T Club
[/color]
Re: To Spray Gray or not, that is the question? [Re: 472 R/T SE] #28009
06/05/06 10:07 PM
06/05/06 10:07 PM
472 R/T SE Offline
472 R/T SE  Offline
No lines from being dipped tho.
Re: To Spray Gray or not, that is the question? [Re: 472 R/T SE] #28010
06/06/06 01:36 AM
06/06/06 01:36 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
They say a picture is worth a thousand words...
Re: To Spray Gray or not, that is the question? [Re: Troy] #28011
06/06/06 08:56 AM
06/06/06 08:56 AM
midwest
sg333e Offline
super street
sg333e  Offline
super street
midwest
Be careful with the Satin Clears, they will yellow especially if they are around heat. Nice work.
Hobbies and associated message boards: 1970 Cuda 440+6 FE5 H6X9 4 SP> Moparts.com 1987 Grand National (422rwhp/566tq)> TurboBuick.com 2008 BMW 335 TT 6MT> E90Post.com 2008 Gary Fisher HiFi Plus 29er > MTBR.com 2008 German Shorthair Pointer > Shorthairs.net
Re: To Spray Gray or not, that is the question? [Re: 1_WILD_RT] #28012
06/06/06 03:39 PM
06/06/06 03:39 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Troy
I just ordered the Krylon. I will have it in a few days.
Re: To Spray Gray or not, that is the question? [Re: Troy] #28013
06/06/06 06:29 PM
06/06/06 06:29 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Has anyone used the method of pouring the paint into a bucket filled with water, where the paint floats on the top and coats the item as you dip it in?
After reading all of this I'm think of finding the right shade of Minwax and and trying that on the LCA's
Re: To Spray Gray or not, that is the question? [Re: A12] #28014
06/07/06 10:48 AM
06/07/06 10:48 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
....by doing that I bet you could also tint the color with paint....
Re: To Spray Gray or not, that is the question? [Re: Troy] #28015
06/07/06 11:52 AM
06/07/06 11:52 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I "heard" this was the method used to coat/paint parts like the torsion bars and the reason they have the drips on them (along most of the length, what I would assume was the bottom?)
Re: To Spray Gray or not, that is the question? [Re: A12] #28016
06/09/06 01:41 PM
06/09/06 01:41 PM
Olympia WA
rocketresto Offline
rocketresto  Offline
Olympia WA
We float paint and dip small parts fairly often. It looks very close to NOS parts, defenatly how some were done. I like your idea for LCA's, maybe tinted clear would work better?
Re: To Spray Gray or not, that is the question? [Re: 1_WILD_RT] #28017
07/02/06 05:35 PM
07/02/06 05:35 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Well Randy, I like your style. I got the Krylon battery and I'm very happy with it. It dries hard and looks good. I think it is the closes I have seen so far. Here are some pictures.
Page 1 of 3 1 2 3
