Re: '68 RR/GTX hood blackout ?
[Re: 68jim]
#2799819
07/22/20 02:23 PM
07/22/20 02:23 PM
Posts: 21,526 N.E. OHIO, USA
A12
N.E. OHIO, USA
Probably the one area I cheated on was painting the inserts fully (top and bottom) vice most inserts just being painted on the top and some small overspray on the bottom edges. The hard part about the 68 inserts was the engine callout plate hardware and plastic gaskets. It took some time to gather the unique screws from various members on Moparts. I think years later I helped out another member with a couple that I had left over. Totally agree, and knowing that with my '68 rr and especially the callout plate attachment screws I made sure I documented the screws size and shape incase I misplaced or lost any of them. I still don't know if they are available??? I also took photos of other parts if anyone needs something. Mike
[Re: 68jim]
#2799888
07/22/20 04:38 PM
07/22/20 04:38 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Are those 1/4x20 thread? Looks like you could probably drill out and tap a regular 1/4x20 bolt to accept a small phillips head machine screw.
On second look, those are a lot smaller then 1/4x20.
[Re: 68jim]
#2800327
07/23/20 05:49 PM
07/23/20 05:49 PM
Posts: 20,852 A collage of whims
topside
A collage of whims
Yeah Jim, you're right. The patch is 30" from rear of patch to its front peak. The guide I'm referring to is from Performance Car Graphics FWIW. They also state 2.5" from rear of hood @ center to rear of patch. To me, the scoops' rear edge will dictate that. I don't doubt there were variances, but bottom line is to lay it out with an eye to proportion. I've never seen a factory blueprint for '68 like I have the '69, either. Out of 11 (IIRC) '68 - '69 RRs I've owned, this is my 1st '68 with "the patch". This one's Q1 like my last Hemi RR, though it's only a 383 car. And yeah, that black Hemi RR is wicked; owned a black one way back, sold it...
