Small block guys will like this: #2799424
07/21/20 03:05 PM
07/21/20 03:05 PM
USA
hudsonhornet7x Online content OP
hudsonhornet7x  Online Content OP
USA
I don't know much about small blocks but this looked good to me:
https://www.hotrod.com/articles/la-...SM9QGgGEm2Uc90Z5pphTBUdlguwDI-JY7hu9Ctw0
Re: Small block guys will like this: [Re: hudsonhornet7x] #2799438
07/21/20 03:39 PM
07/21/20 03:39 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You are correct, I like that a lot.
Some interesting ideas in that build.
Re: Small block guys will like this: [Re: topside] #2799440
07/21/20 03:44 PM
07/21/20 03:44 PM
USA
USA
Yeah I need to learn about small blocks. I had no idea a stock small block ( factory block) could make that kind of power and not hurt something.
Re: Small block guys will like this: [Re: hudsonhornet7x] #2799444
07/21/20 04:06 PM
07/21/20 04:06 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My question would be, how long will it take it? Very interesting build for sure.
Re: Small block guys will like this: [Re: justinp61] #2799446
07/21/20 04:09 PM
07/21/20 04:09 PM
USA
USA
I am curious about that as well.
Re: Small block guys will like this: [Re: topside] #2799454
07/21/20 04:18 PM
07/21/20 04:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That is a sweet LA.. and a ton of work on it
wave
Re: Small block guys will like this: [Re: MR_P_BODY] #2799465
07/21/20 04:34 PM
07/21/20 04:34 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Very cool.
Re: Small block guys will like this: [Re: hudsonhornet7x] #2799474
07/21/20 05:04 PM
07/21/20 05:04 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
A magnum block is stronger than any production LA block except maybe a TA but even then I think I would take the magnum. It has stronger metal you can feel when grinding clearance for strokers, it has some more meat around where the mains meet the pan rail and some other little goodies. I also see in those pics he tied 3 of the cam bearings together with a home made brace since he was not using the factory roller lifter set up.
Re: Small block guys will like this: [Re: hudsonhornet7x] #2799536
07/21/20 08:12 PM
07/21/20 08:12 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I have asked in the past on here (because someone coined the phrase "split a block") who has "split a block"?
No replies. No photos. No proof.
When production Gen 3's are almost up to 900hp with 5 years warranty you can be certain 800hp LA's are well within reason. twocents
Much enjoyed the post, thanks! up Imagine this build on a street car with the 4.25 crank. That's where I'm going.........
Mo' Farts
Moderated by "tbagger".
Re: Small block guys will like this: [Re: Grizzly] #2799557
07/21/20 09:15 PM
07/21/20 09:15 PM
USA
USA
Grizzly that sounds pretty awesome to me! I am glad I shared this article and imagine this: No arguments, no political junk. Here we are talking about Mopars on a Mopar website. Who would have thunk it?! PS, I would love to see your project if you have some pictures.
Re: Small block guys will like this: [Re: hudsonhornet7x] #2799559
07/21/20 09:26 PM
07/21/20 09:26 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Great build.
We had several threads about this samemotor on here about a year ago. After it was built, and pre dyno
He actually screwed my shortblock together for me( Jack Barna) great guy. Been friends with his dad a long time, they are local here in West Mi
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Small block guys will like this: [Re: hudsonhornet7x] #2799560
07/21/20 09:34 PM
07/21/20 09:34 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
I've studied the ls7 and the big flow, big lift numbers......factory. I've studied the Gen 3's and their big flow numbers.......factory:
I don't see why 700+ torque in a six pack 440 small block isn't doable on a street car with untouched Victor heads. twocents
My problem is the aftermarket reliabilty of the rockers. So, unless someone tells me Hughes rockers will last 80,000 miles I won't be doing anything. On paper, it will work though.
Mo' Farts
Re: Small block guys will like this: [Re: Grizzly] #2799562
07/21/20 09:38 PM
07/21/20 09:38 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I think I read that BB stamped rockers will work on the SB victors.
On a side note, I split a 273 block from the main bearing to the cam bearings on all 5
Re: Small block guys will like this: [Re: HotRodDave] #2799568
07/21/20 09:54 PM
07/21/20 09:54 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
I would have to have visual proof of this.
As for splitting your 273, again, photos to back up your claim, please.
Mo' Farts
Re: Small block guys will like this: [Re: Grizzly] #2799584
07/21/20 10:48 PM
07/21/20 10:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On my stock block and W-2s I had BB roller rockers on it(they were packaged as SB rockers) but
I had issues with them from the get go till I started measuring them.. The portion that was on the
valve was long and they needed caps.. at about 7000rpm they would kick out the caps.. I had
a pile of cap in the valley.. glad I screened it.. soon after I got SB ones then things were fine and
it would rev like it should have and didnt need caps.. I learned alot
wave
Re: Small block guys will like this: [Re: Grizzly] #2799590
07/21/20 11:02 PM
07/21/20 11:02 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Back in 97 everyone didn't just have digital cameras everywhere so I must be lying.
Re: Small block guys will like this: [Re: HotRodDave] #2799598
07/21/20 11:21 PM
07/21/20 11:21 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Yes Dave, I have yet to see 525 pounds of cast iron "split" into pieces. Even if you tied it to a couple of D8 Cats in opposite directions I doubt you could tear any engine block apart. rolleyes This from a former Heavy Equipment Operator and Metal Worker.
There's a few videos of 2000hp, 100psi boosted tractor pullers shearing the head bolts off and throwing parts everywhere, is that what you were doing with the 273?
Mo' Farts
Re: Small block guys will like this: [Re: Grizzly] #2799604
07/22/20 12:13 AM
07/22/20 12:13 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Re: Small block guys will like this: [Re: Neil] #2799613
07/22/20 01:41 AM
07/22/20 01:41 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
A friend has built a few engines with these heads and tends to steer his customers toward T&D rockers. He has used the Hughes rockers on one or two engines. Harland Sharp sent him out a rocker system, but it was so far away from working, it was sent back . I believe the arms were BBM units, I've got pictures somewhere.
Alan Jones
Re: Small block guys will like this: [Re: LA360] #2799617
07/22/20 03:08 AM
07/22/20 03:08 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
My 418/360, production head engine made near 700hp. 1972 360 block with 587 cyl. head castings. 3050+ pound car ran in the 9.60s at 136mph, with 1.26 60ft times, or better cause 60 footed on rears alot of the time. 2700+ passes and no valve job, pistons or crank never out of the block. Very underated engines. Engine in car now is 1972 340 block with 60779 edelbrock heads. Car has ran exactly the same as combo with factory heads. Lost weight with the eddys but had to put the weight back on in the form of wheelie bars.
