Re: A833 choices
[Re: Bull1tt]
#2799359
07/21/20 12:36 PM
07/21/20 12:36 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
The input shaft and the gears inside are a little bigger and made out of better metal according to some of the Mopar drag engineers at there old seminars. All the gears have bronze bushing inside them also instead of steel on steel like the 23 spline have which is better also There have three different ratio also so make sure you get the one you like
Re: A833 choices
[Re: BigBlockGTS]
#2799390
07/21/20 01:44 PM
07/21/20 01:44 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Been running an 18 spline, slick shifted for many years. Heavy B body running low 11's. I pull the front tires at launch with 1.5 short times. I also run the same set up on the street, except for the slicks! Never broke anything in the tranny. From what I've researched, a 23 spline is good for around 550 ft/lbs, where the 18 spline is good for 650 ft/lbs. Both transmissions are very strong for a production unit. There are better ones out there, but that's another consideration.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: A833 choices
[Re: 68LAR]
#2799680
07/22/20 09:50 AM
07/22/20 09:50 AM
Posts: 876 Missouri
jwb123
Missouri
I ran an A833, pro shifted, vertical gate shifter 23 spline, many years ago, ran low 10's with a 340. Never broke the transmission. Ran a three puck metallic type clutch. I found that if the clutched slipped a tiny bit, on the launch, the car ran faster, and was pretty easy on parts. I used to run an aluminum flywheel, and the riveted in heat shield would start to warp about every 150 runs or so, I could feel a little chatter driving around in the pits, I simply went home and replaced the heat shield, that was the sacrificial wear component. I know a guy with a fast Pontiac stick car, he runs low 9's and he said the same thing, clutch setup is what determines the life of the transmission. On a automatic, the fluid in the converter absorbs some of the shock off the line, a stick car uses the springs in the clutch hub and some slippage to do the same thing.
