going from a p235/70r15 on a 15x7 to a p275/60r15 15x8 5 BS #2799043
07/20/20 06:03 PM
07/20/20 06:03 PM
APACHE JUNCTION AZ
Joesixpack Offline OP
APACHE JUNCTION AZ
OK need some new rear tires
currently have a p235/70r15 on a 15x7 american 5 spoke, back space 3.5
would like to use a p275/60r15 on a 15x8 5 inch backspace
66 Belvedere I stock length 8 3/4 ss spring in stock location.
what do you think? have more room now to the spring than to the wheel lip probably have to trim the wheel lip on the quarter panel as it extends in towards the tire
Re: going from a p235/70r15 on a 15x7 to a p275/60r15 15x8 5 BS [Re: Joesixpack] #2799051
07/20/20 06:18 PM
07/20/20 06:18 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I get a better patch with 275s on 10" rims. The 8" rims pull the edges off the pavement. Have you measured how much rubber is in contact with the 235s on 8" rims? I haven't tried it, so I don't know. But my experience with the 275s is that they like the 10" rims. 235s might be happier on 8s and do as well as 275s on 8s. twocents
Master, again and still
Re: going from a p235/70r15 on a 15x7 to a p275/60r15 15x8 5 BS [Re: DaveRS23] #2799060
07/20/20 06:48 PM
07/20/20 06:48 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
there is no way to get a 10 inch rim on this car. the wheelhouse area is a lot smaller than a later b or e body
Re: going from a p235/70r15 on a 15x7 to a p275/60r15 15x8 5 BS [Re: Joesixpack] #2799079
07/20/20 07:36 PM
07/20/20 07:36 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Exactly what I have on my 62 wagon,78 Ramcharger 15x8, 5 1/2 back spacing 3/4" from spring 1" from fender lip. Don't know how the 62 wheel opening compares with 66.
Re: going from a p235/70r15 on a 15x7 to a p275/60r15 15x8 5 BS [Re: 62maxwgn] #2799088
07/20/20 07:49 PM
07/20/20 07:49 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I think you have small wheel wells. P255/60R15's in the back of my 51. Room for much more. 295's easy, maybe even 305's if I can get the perfect backspacing.
Re: going from a p235/70r15 on a 15x7 to a p275/60r15 15x8 5 BS [Re: Sniper] #2799111
07/20/20 08:17 PM
07/20/20 08:17 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
66&67 Bbody have small wheel wells ,plus the shape of it is not round like a tire.
Re: going from a p235/70r15 on a 15x7 to a p275/60r15 15x8 5 BS [Re: Joesixpack] #2799112
07/20/20 08:18 PM
07/20/20 08:18 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
15x8.5 supertrick
Re: going from a p235/70r15 on a 15x7 to a p275/60r15 15x8 5 BS [Re: Joesixpack] #2799113
07/20/20 08:19 PM
07/20/20 08:19 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
15x8.5 supertrick
Re: going from a p235/70r15 on a 15x7 to a p275/60r15 15x8 5 BS [Re: Joesixpack] #2799116
07/20/20 08:21 PM
07/20/20 08:21 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
same wheel
Re: going from a p235/70r15 on a 15x7 to a p275/60r15 15x8 5 BS [Re: Joesixpack] #2799137
07/20/20 09:19 PM
07/20/20 09:19 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
I put a pair of the newer 15x8 torque thrusts (4.5 backspace) with 275-60x15 mastercrafts on the back of my '65 coronet. easy install and really like them.
Re: going from a p235/70r15 on a 15x7 to a p275/60r15 15x8 5 BS [Re: Joesixpack] #2799250
07/21/20 08:45 AM
07/21/20 08:45 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I was not suggesting the 10" rims for your application.
Re: going from a p235/70r15 on a 15x7 to a p275/60r15 15x8 5 BS [Re: Joesixpack] #2799306
07/21/20 10:37 AM
07/21/20 10:37 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
The 5" BS will help but a lot of it comes down to the section width of the tire. I looked at section widths as much as I did the tire size. On my 67 I'm have 15 x 8 on 4.5"BS steel wheel with M/T ET street 255/60 that fits in there nicely. A 275/60 will work with a 4.5 BS on a 7" wheel with a smaller section width but it will still be tight on the quarter panel side. These cars are very space limited as opposed to earlier and later B bodies.
Re: going from a p235/70r15 on a 15x7 to a p275/60r15 15x8 5 BS [Re: Belvedere1] #2799315
07/21/20 10:57 AM
07/21/20 10:57 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
when you say tight on the quarter panel side, is that at the lip of the wheel opening or is it where the inner wheel housing curves in towards the wheel a few inches above the wheel opening?
Re: going from a p235/70r15 on a 15x7 to a p275/60r15 15x8 5 BS [Re: Sniper] #2799337
07/21/20 12:01 PM
07/21/20 12:01 PM
Kirkland, Washington
Pacnorthcuda Offline
What the hell is wrapped around that leaf spring???
Re: going from a p235/70r15 on a 15x7 to a p275/60r15 15x8 5 BS [Re: Pacnorthcuda] #2799362
07/21/20 12:38 PM
07/21/20 12:38 PM
moparx Offline
moparx  Offline
if i'm not mistaken, that is the factory "wrapping" used up to about 57 or 58 [?] that was supposed to contain a kind of grease that kept the leaves from binding against each other.
beer
Re: going from a p235/70r15 on a 15x7 to a p275/60r15 15x8 5 BS [Re: krautrock] #2799367
07/21/20 12:50 PM
07/21/20 12:50 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
Could be both scenarios. Its definitely tight at the wheel lip (may need trimmed) and depending on the tire height and section width of the tire it can be tight in the upper wheel house too. And, also consider the leaf spring as well. If the springs are worn and "squatty" you can run into problems there as well. I advise to go on the smaller side with tire and wheel combos if you are leaving everything in a stock configuration.
