Page 2 of 3 1 2 3
Re: Setting valve lash, different ways discussion [Re: fourgearsavoy] #2798826
07/20/20 08:43 AM
07/20/20 08:43 AM
New York, USA
Chargerfan68 Offline
New York, USA
I was told by a pretty experiened engine builder that i shoild almost be bleeding when i am done checking/setting lash, even on a roller tipped motor. He said “no way am i going to begin to compress a 500-600-700 + pound spring by trying to insert a feeler gauge in there. So, if the next size up goes in there , no matter how hard i try, lash is too loose. Plain and simple, he said. I’ve been doing like that ever since.
Re: Setting valve lash, different ways discussion [Re: Chargerfan68] #2798840
07/20/20 09:54 AM
07/20/20 09:54 AM
Nevada
merpar Offline
merpar  Offline
Nevada
Sorry Charger, I disagree. when you start to compress a valve spring you are not compressing the full poundage. To move it .005 only takes a few pounds. Think about it full open pressure is 500 lbs. To start compressing is very slight.
Re: Setting valve lash, different ways discussion [Re: merpar] #2798850
07/20/20 10:07 AM
07/20/20 10:07 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Not talking full open pressure, seat pressure but that is still 200 or better, Im in agreement with the man above your post. Sure, you could drive a feeler gauge in there with a hammer, but not by your hand, at least not mine. I have also checked with the next size gauge to check my work, if it wont go, what I did was right.
My take is, if you do it the same everytime, your results will be as accurate as you can make them. Also I was told to slide the feeler gauge in at a right angle to the roller tip wheel, not parallel to the rocker. The wheel turning will make you think its looser than it really is. Ive tried it both ways and do the right angle checking.
Re: Setting valve lash, different ways discussion [Re: dthemi] #2798853
07/20/20 10:15 AM
07/20/20 10:15 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Originally Posted by dthemi
Just a thought
Prostock is the pinnacle of drag race pushrod technology. Walk through the pits and watch a PS team run over the valves for lash, and spring tension. I've never once seen a team look for crank position. Good enough for them, good enough for me.
Comp guys are the same way EO/IC is the way I have always used with some pretty big sticks
Re: Setting valve lash, different ways discussion [Re: Al_Alguire] #2798864
07/20/20 10:29 AM
07/20/20 10:29 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
This was a story told to me several years back by a very experienced Comp Cams employee that, before he retired, worked a lot with Super Stock racers.
"Don’t use that chart. Do it like this: Look at one cylinder…rotate the motor by hand….set intake lash when exhaust rocker starts to move. Continue to rotate and set the exhaust when the intake rocker goes all the way down and is about ¾ of the way back up. You can do anything from your Chrysler to a Subaru to Ferrari that way and always be right. I was at the national event in Columbus one year with a very famous Chrysler Super Stock racer (to remain un-named) and was sitting on his trailer door shooting the breeze as he was running the valves before dinner. I watched as he did the Chrysler chart thing. When he was done, we ran through them again using the approved method I listed above. Some of the settings were .004”-.006” different. The next morning he went about .03 faster than the prediction. The ones in error made the settings too loose and not only lost performance, but if the desired settings were on the loose side anyway, for performance, the risk was there to fail a valve or lifter by making too severe."
Re: Setting valve lash, different ways discussion [Re: DrCharles] #2798875
07/20/20 10:54 AM
07/20/20 10:54 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Originally Posted by DrCharles
If you set each cylinder at TDC firing stroke, both valves are completely closed and nowhere near the ramps... What am I missing? shruggy
(Other than having to turn the engine 90 degrees eight times?)
Rocker shaft, cam, and pushrod flex. Check it your way, then check the intake again as the exhaust valve is starting to open, the intake will loosen up for the reasons I mentioned before.
68 Barracuda Formula S 340
Re: Setting valve lash, different ways discussion [Re: Cab_Burge] #2798893
07/20/20 11:54 AM
07/20/20 11:54 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted by Cab_Burge
"Honest" Bob Hickman, R.I.P.,(the So CA wedge God, guru, told me years ago to make all my lash adjustments so pushing the feeler gauge in with a finger would be tight enough that I thought the feeler gauge would cut my finger.
That's the part that varies, the technique like Jim said. I have watched the Top Fuel guys and they generally drag the feeler gauge through sideways with both hands....the key word being "drag" rather than push in.
Re: Setting valve lash, different ways discussion [Re: John_Kunkel] #2798926
07/20/20 01:23 PM
07/20/20 01:23 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
technique and consistency mean more to me than the actual method. I always do the exhaust cracked open/ intake closed thing. I never trust my first pass on big rollers and always go thru them twice. find a method that works for you and your parts. I've found that doing frequent lash adjusting is more related to human error/inconsistencies than parts problems, but having a good maintenance schedule can nip problems in the bud.
Re: Setting valve lash, different ways discussion [Re: John_Kunkel] #2798934
07/20/20 01:32 PM
07/20/20 01:32 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
From what I’ve seen...... the user technique and feel have at least as much influence on the actual lash as the method being used.
I was at another shop helping another builder sort out a combo on his dyno.
We had made a few pulls and checked the lash since it seemed a bit noisy to me.
It was his build, his shop, his dyno....... so I ran the starter button and he did the adjusting.
After he was done I checked a few myself.
I like there to be a lot of drag on the feeler gauge....... he didn’t do it that way.
I could stuff a blade about .005” thicker in there than if I had done them.
This was not a cam that used a particularly large lash setting.
The card called for .020, and I could jam a .024-.025 in there.
We made a few more pulls...... still noisy.
Went thru the valves again, only I set them the way I like it.
He looked at me like I was crazy when I was jamming those blades in there.
(He liked a very light smooth drag. It took him forever to do each valve...... and get it juuuuust right)
Noticeably quieter operation after I set them....... and picked up some power too.
In that particular case, the motor didn’t really respond favorably to the smaller net duration that came from the looser lash setting.
Sometimes they do....... sometimes they don’t.
Re: Setting valve lash, different ways discussion [Re: merpar] #2798972
07/20/20 03:12 PM
07/20/20 03:12 PM
New York
polyspheric Offline
polyspheric  Offline
New York
(Open pressure - closed pressure) ÷ lift = spring rate in lbs. per inch. Lbs. per inch at the valve × rocker arm ratio = spring rate on the cam, tappet, pushrod, adjuster.
Example: 800 lbs. open - 300 lbs. closed = 500 lbs., ÷ .800" lift = 625 lbs. per inch deflection rate; with a 1.7:1 rocker arm the cam etc. sees 1,062.5 lbs. per inch.
Depressing the adjuster .010" requires 10.625 lbs. of pressure.
Boffin Emeritus
Re: Setting valve lash, different ways discussion [Re: polyspheric] #2798983
07/20/20 03:24 PM
07/20/20 03:24 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
When you mic a crank do you tighten it like a c clamp?
Doug
Re: Setting valve lash, different ways discussion [Re: Bad340fish] #2798997
07/20/20 03:50 PM
07/20/20 03:50 PM
Minn
SportF Offline
SportF  Offline
Minn
This is a neat discussion. Um, I always did the TDC both valves deal. I can now see checking the intake under exhaust loading, as they overlap, but no need to check the exhaust under intake load because that doesn't happen.
I think what I will do is check a couple intakes this way, chaInge my setting spec, then go back to the TDC method.
Re: Setting valve lash, different ways discussion [Re: 340Cuda] #2798999
07/20/20 03:51 PM
07/20/20 03:51 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
That's the way I was taught by my Dad many years ago, with a slight drag when pulling the feeler gauge through.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Setting valve lash, different ways discussion [Re: SportF] #2799023
07/20/20 04:55 PM
07/20/20 04:55 PM
gregsdart Offline
gregsdart  Offline
remwmber that all pairs of lifters for a cylinder are seperated by a lifter from the other bank.
Re: Setting valve lash, different ways discussion [Re: gregsdart] #2799159
07/20/20 10:05 PM
07/20/20 10:05 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I've always found feeler gauges I've had to be slightly undersized if you mic them up
Re: Setting valve lash, different ways discussion [Re: GTX MATT] #2799194
07/20/20 11:46 PM
07/20/20 11:46 PM
gregsdart Offline
gregsdart  Offline
Obviously different methods are working well for most. So IMHO it boils down to your combination of parts and preferance. You can get away with a lot when using solid lifters and low spring pressures and modest duration. Sounds to me like those pro stock cams are quite rigid and can also tolerate some deviation. I understand they run less duration that most would think.
My deal is a stock size cam core with a .510 lobe on it, which limits the base circle. So it flexes, and the ramps are 30 degrees (yep!) Long on each side of the lobe before reaching the .050 lift point. Due to the profile and ramps Jones said no more than .002 lash change in either direction. That and needing to keep an eye out for valvetrain trouble forces me to be as accurate as possible.
One question- what do the cam companies say is the proper "feel" for setting lash? I shoot for a modest drag, light enough that i can't feel anything with a .001 smaller gauge.
Re: Setting valve lash, different ways discussion [Re: polyspheric] #2799236
07/21/20 07:49 AM
07/21/20 07:49 AM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
are you concluding that while ignoring seat pressure? sum of forces.......
Re: Setting valve lash, different ways discussion [Re: gregsdart] #2799307
07/21/20 10:41 AM
07/21/20 10:41 AM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
I’m going to say that if you set them to say, .020”...... and I checked them..... I would say they were .002”-.004” looser than that.
I’m just looking for repeatability, more so than being absolutely exact on what the actual lash measurement is.
I like it where you basically can’t get the next larger blade in.
If it want to try a looser setting, I use a thicker blade.
I’m def not saying my way is better, but after 30 years of playing with that stuff on the dyno, that’s what my system has evolved into.
Re: Setting valve lash, different ways discussion [Re: gregsdart] #2799314
07/21/20 10:57 AM
07/21/20 10:57 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Greg that is true but it still won't help counteract any flex in the rocker shaft. On a set of paired rockers it may make little or no difference. I believe the first time I read that it was on here from Monte Smith, I then checked my rockers to see what it did. I don't recall the number but it was pretty surprising when I checked it with my Erson W2 rockers, however the Erson Rockers had a dinky shaft that was almost floppy compared to the Harland Sharp rockers I run now.
Re: Setting valve lash, different ways discussion [Re: Bad340fish] #2799328
07/21/20 11:43 AM
07/21/20 11:43 AM
central il.
second 70 Offline
second 70  Offline
central il.
Since a hemi has separate rocker shafts for intake and exhaust would there be any push rod flex at TDC?
Page 2 of 3 1 2 3
